Hey all.
I just bought a Casio Algebra FX 2.0 plus from ebay. It arrived , was working , but there was a moving part inside it. I got curious and opened inside it. I saw the moving part was a capacitor ( a small black cylinder, 3 things written on it, "10V" - "1000micro farad" - "SMG"). It was probably thorn apart from the calculator while shipping.
From what I learned at school , capacitors are for holding electricity like a battery. My question is how is it possible that the calculator works perfectly without this part? Anyone knows what is the use of such capacitor in a calculator? Do you think there will be problems in the future? Should I just solder it in its place?
Thanks for your helps.
Moving part inside my algebra fx2 !!
Marlon
, Mar 28 2003 08:30 AM
Posted 28 March 2003 - 08:30 AM
Posted 28 March 2003 - 08:41 AM
I dropped my calc to the floor once, after that something has been moving around inside *heh*
Since it still works perfectly, I never cared to open it though.. (assumed it was just a piece of "useless" plastic the fell lose)
Posted 28 March 2003 - 09:54 AM
Capacitors are used to deliver higher amount of energy than what would be available straight from batteries.
The use of it in a calculator is propably to make the lcd screen turn on (only quessing here).
Posted 28 March 2003 - 09:20 PM
Yes you should try to solder it in its place if possible else you may meet with strange problems in the future...
