Problem On A Ti 84 Se Plus
Posted 05 June 2007 - 08:01 PM
What can i do?
Posted 05 June 2007 - 11:09 PM
I know that I shouldn't be posting here about the Ti
You should post in a TI forum about this.
What can i do?
Get a CASIO graphing calculator (I suggest a CASIO fx-9860G, you're using a TI-84 anyways, so you probably don't need the CAS anyway) and join the community.
Posted 06 June 2007 - 10:50 PM
But posting this on a TI site would get you better results. I suggest posting in my group's forum www.revsoft.org I know we have a lot of members with 84+ SE series calcs that can perhaps lend a hand.
Posted 07 June 2007 - 01:46 PM
The problem is halfway solved because one friend gave me the files and now I don't need to install the prog.
Thank for your help.
Posted 09 June 2007 - 02:09 AM
Posted 09 June 2007 - 02:33 PM
I have a Casio CFX 9850 GB Plus, but to do my Fisic-Quimic exam I will use the Ti because it's way faster to do the txt helps on the PC and them pass it to the calc.
Well, I still suggest getting a CASIO fx-9860G. It's the fastest calculator on the market right now and it has more features than a TI-84. There's also the fx-9860SD which has a SD card slot allowing up to 1GB of storage. You can read TXT files on the calculator using the TXTREAD add-in.
Posted 13 June 2007 - 01:13 AM
the 84s can use the mini usb port to transfer files from flashdrive, provided you have the software on the calc. But that isn't a built in feature it's a seperate program from one of the members of the community.
