9860g Help (please!)
7 replies to this topic
#1 buz260
buz260
  • 4 posts
    Casio fx-9860G
Posted 13 June 2007 - 10:42 AM
Hi if you could help me that'd be great. Firstly how can i configure it so that irrational numbers are displayed as fractions with roots etc... eg cos30 = root3/2. The lesser casio calculators can do this, so surely my new graphical one can too??
Also how can i get the modulus function on my calculator (ie how could i type eg. |x|)?
Thanks - got an exam tomorrow (a level maths) so would really appreciate a fast response. Cheers
#2 TyYann
TyYann
  • 107 posts
    Casio fx-4000P (since 1988)
    Casio CFX-9850GB PLUS
    Sharp EL-9900
    Casio fx-9860G SD
    Casio fx-9860GII SD
    Casio Graph 90+E
    TI-83 Premium CE (no Python)
    and a 25-column abacus...
Posted 13 June 2007 - 12:15 PM
To get answers like cos30 = root3/2 on a calculator, you need a CAS calculator. fx 9860 is not CAS...
There is no modulus modulo function on this calc either. You need to do it manually (eg : divide by the modulus and find the remain of the division).
I wrote this program for you :
"A Mod B: A"?->A
"B"?->B
A-Int (A/B)xB->C
If C<0
Then C+B->C
IfEnd
Where
-> is [->]
/ is [/]
Hope this helps.
EDIT : Change Modulus to modulo. I misunderstood, sorry.
#3 caspro
caspro
  • 216 posts
Posted 13 June 2007 - 12:37 PM
By modulus, he means |x| i.e. Abs X (not modulo) ;)
Abs is on optn f6 f4 f1 or from the catalog
and no the 9860 does not have exact values for trig functions built-in.
#4 buz260
buz260
  • 4 posts
    Casio fx-9860G
Posted 13 June 2007 - 12:55 PM
Thanks v. much for all the help - have found modulus function thanks to caspro. You said it doesnt have the exact values "built in" - is there a way of putting something on it so exact values are displayed?
#5 TyYann
TyYann
  • 107 posts
    Sharp EL-9900
    Casio fx-9860G SD
    Casio fx-9860GII SD
    Casio Graph 90+E
Posted 13 June 2007 - 01:00 PM
Pardon my French... :rolleyes:
#6 buz260
buz260
  • 4 posts
    Casio fx-9860G
Posted 13 June 2007 - 03:02 PM
any other suggestions.... :lol: - exams in less than 24 hours
#7 caspro
caspro
  • 216 posts
Posted 13 June 2007 - 04:38 PM
If you don't want to memorise the exact values then here is a method to
work them out.
Type cos 30 or whatever ( make sure the calc is in deg mode first )
You get the answer 0.866025....
Now all the exact values involve square roots and 1/sqrts
(except for easy results like 0 or 0.5 which don't need any further simplification)
So just square the result and see what you get.
e.g. 0.866....^2 = 0.75 which is clearly 3/4 which means the answer was =sqrt (3/4) which simplifies to = (sqrt 3)/2
another example:
tan 30=0.57735..... squaring gives 0.333..... i.e. 1/3 so answer was sqrt (1/3) = 1/sqrt 3
#8 buz260
buz260
  • 4 posts
    Casio fx-9860G
Posted 13 June 2007 - 09:46 PM
good idea - thanks... i think i almost know them now anyway after thinking about them so much!
Thanks 4 all the help
