Ok, after searching the forums, i didn't find any topic on how to get into complex mode with Fx-95ms.
So to get into Complex/Base mode, follow these steps:
1. Go into SD mode
2. Press 9 and keep hitting the M+ key until it says "Data Full"(should be at about n=80)
3. Press "=" and "2"(ESC)
4. Press the up arrow and type "13" repetitively until the numbers stop moving then press "="
5. This time when the option for "EditOFF" and "ESC" comes up, press "0" then "1"(pressing 0 is important)
6. Now press "mode" and there you have it.
7. For Base mode, press "mode" again.
Fx-95ms Complex/base Mode
Avlis
, Aug 05 2007 04:27 AM
