Help, Help, Help!
#1 frank850102
frank850102
    fx9860G SD
Posted 01 September 2007 - 06:34 AM
Can anyone tell me that if there is virus in my computer, and when I transfer data between my fx9860G SD calculator and my computer by USB cable or by SD card, is the virus gonna be trsferred to my calculator? And how is it gonna affect the performance of the calculaotor?
If so, what am I supposed to do to get rid of the virus in my calculator?
#2 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 01 September 2007 - 03:08 PM
Hello frank850102 and welcome to the UCF! :D
Well if you have a virus on your PC, there's no way it's going to mess up your calculator. In fact, I'm highly sure there are no viruses for the fx-9860. If for some reason your calculator is malfunctioning (which makes you think there is a virus) just try reseting your calculator.
#3 kanejunior
kanejunior
  • 2 posts
    casio fx-9860gii sd
Posted 08 November 2012 - 04:02 PM
yes there are viruses
my Casio fx-9860 GII sd
not working I get on the screen
system error
reboot: exit
initialize: exe
illegal err code
target = 00000000
pc = 00000000
when I give an update on empiesa exe but stops short ends and the screen turns white
I can not connect to my pc
that when connected to the display
goes a line in the middle
as when older monitors are turned off
not try to run any program - was entering e-activities and so did my calculator and try to reset and it did not work, and not to do so I ask for help in this forum that there are experts here and I guess someone already ran into a similar problem
Copy all the information from another calculator to Blast sd and jammed in my calculator to try to see if up and remove the memory and put Blast on my pc detect virus, so my memory format and went back to bring my calculator , then take it out and connect it to my pc again and again
detecting the virus
Edited by Forty-Two, 09 November 2012 - 01:24 AM.
Nuked those colors
#4 flyingfisch
flyingfisch
  • Deputy
  • 1891 posts
    fx-9860GII
    fx-CG10 PRIZM
Posted 08 November 2012 - 04:31 PM
Hello kanejunior and welcome to UCF! You should introduce yourself.
So what exactly is your problem? Did this start happening after you put a certain program on your calculator? If so, try to update the OS. Also, you can try resetting the main AND storage memories.
#5 kanejunior
kanejunior
  • 2 posts
    casio fx-9860gii sd
Posted 08 November 2012 - 04:41 PM
and try to do all that and nothing works
not even off my calculator I can do nothing
