Replace Battery On Calculator?
#1 matthu
matthu
  • 4 posts
Posted 28 September 2007 - 07:55 PM
When I opened my Casio fx-3600Pv for a battery replacement the old one
popped out and so I didn?t see how to place the new one. Should the plus
side on the new battery be placed down towards the electrical components or
vice versa? It seems to work both ways!
#2 betoe
betoe
    UCF Spanish Translator
  • 846 posts
  • Interests:Electronics, SW development, automotive. Swim->bike->run
    Algebra FX2.0 (R.I.P.), Classpad 300
Posted 29 September 2007 - 06:43 AM
Do you have the user manual?
Search for it on internet. Unfortunately we have a manual links post, i search for your calculator and found it, but the file is not available :( , so try for a similar model. Take a look to this one:
FX-3650:
http://ftp.casio.co....650_3950P_E.pdf
Page 55 have an image an explanation of how to do it.
Good luck!.
#3 matthu
matthu
  • 4 posts
Posted 29 September 2007 - 04:53 PM
Hey thanks, the battery should probably be fitted the same way on my calculator
as on the one you so kindly referred to in the manual. There is no information in my manual about battery change.
By the way, the letter "D" is constantly lit above the zero and can?t be turned off, I?m not sure it was before the battery change, or maybe it was, I haven?t used the calculator for a while?
