Cross Product Problems
Posted 14 October 2007 - 08:36 PM
New member here......
i recently bought a casio fx-9860g calculator mostly to do cross products..........
its an awesome piece of work except...........
i dont know how to do cross products can any one help me???????
Posted 14 October 2007 - 10:06 PM
Posted 18 October 2007 - 12:23 AM
I have written a prog which will do this for you
I will post it when I get home (at uni now)
Enter two vectors and prog returns:
Dot product, cross product
Magnitude of both vectors, magnitude of cross product
and angle between both vectors in radians and degrees....
Posted 18 October 2007 - 06:23 AM
Here is code:
Not sure what the fonts are doing??
I've just cut and pasted straight out of FA-124....
If you give me your email addr. I'll send you the .g1m file...
Or if some one can tell how/where to upload file O'll do that too....
[codebox]Filename:DOTCROSS
ClrGraph?
AxesOff?
ClrText?
Sci 4?
EngOn?
Rad?
'Goto 1?
3->Dim List 1?
"First vector: A"?
"x#E5D1+y#E5D1+z#E5D1"?
"x#E5D1"?->X?
"y#E5D1"?->Y?
"z#E5CE"?->Z?
ClrText?
"Second vector: B"?
"x#E5D2+y#E5D2+z#E5D2"?
"x#E5D2"?->P?
"y#E5D2"?->Q?
"z#E5D2"?->R?
Lbl 1?
ClrText?
?(X'+Y'+Z')->A?
?(P'+Q'+R')->B?
Text 1,73," _"?
Text 7,75,"@7CA@7C"?
Text 7,90,A?
Text 14,73," _"?
Text 20,75,"@7CB@7C"?
Text 20,90,B?
Text 1,1,"_ _"?
Text 7,1,"A.B"?
XP+YQ+ZR->D?
Text 7,20,D?
cos? (D?(AB))->O?
Text 43,1,"Angle AB"?
Text 50,1,"Rads:?
Text 50,25,O?
Text 57,1,"Degs:"?
Text 57,25,O?180???
Text 14,1,"_ _"?
Text 20,1,"A?B"?
{YR-QZ,-(XR-PZ),XQ-PY}->List 1?
?(List 1 '+List 1 '+List 1 ')->C?
Text 28,69,"_ _"?
Text 34,67,"@7CA?B@7C"?
Text 34,90,C?
Text 20,20,"x"?
Text 20,30,List 1 ?
Text 27,20,"y"?
Text 27,30,List 1 ?
Text 34,20,"z"?
Text 34,30,List 1 ?
[/codebox]
Posted 18 October 2007 - 06:30 AM
Think i've managed to upload it to:
http://www.planet-ca...php?showid=1002
Let me know what you think....
Cheers Neil..
Guest_Guest_ripcurl_*_*
Posted 19 October 2007 - 06:25 AM
but how do i get it into my calculator.....
plz forgive my stupidity but im totally new to this whole programmable calculator stuff and i suck at C/ C++
Posted 21 October 2007 - 11:51 AM
You don't need to know anything about C/C++
You need to learn to drive the fa-124 program that came with calc
you can then download my program from:
and send it to your calc via USB cable..
Apparently you need to install fa-124 BEFORE you plug in USB cable or u can have problems....
Or you can work out crosss product by hand:
If vector A=x+y+z
and Vector B=p+q+r
then the cross product:
AxB = (y*r-q*z)+(p*z-x*r)+(x*q-p*y)
Hope this helps
Neil...
Posted 24 October 2007 - 08:29 AM
Hi Rip,
You don't need to know anything about C/C++![]()
You need to learn to drive the fa-124 program that came with calc![]()
If vector A=x+y+z
and Vector B=p+q+r
Hope this helps
Neil...
ummmm
dont wanna sound like a total dumbass but whats fa-124?
Posted 24 October 2007 - 01:49 PM
onto your calculator via a USB cable.
It should be on the CD that came with your calculator
there is a slightly later version here:
https://edu.casio.co...nload/class.php
Under "
fx-9860G series
PC Software
Fa-124 Manual here:
http://ftp.casio.co....en/FA-124_E.pdf
Works with windows Vista too, apparently..
Hope this helps
Neil
