I recently bought an Algebra 2.0 plus and i gotta say it's really helpful.
However, I saved a bad coded program and the calc started to work improperly: it froze while doing some simple operations and i had to reset it very often. At some point it started to show DATA ERROR XX (XX are diferent numbers each time), and it suggested to clean memories. I read somewhere that is a memory error and i sent an email to CASIO Europe to tell them my problem.
They told me that i should take the calc to their provider, which is really far away from me.
So, before sending the calc i wanted to know if there is some way to flash the calc with the usb cable or something i could do to get it fixed without sending it that far
![:banghead:](/dot/public/style_emoticons/default/banghead.gif)
Thank you guys!!
