Code Didn't Work: Simple I/o Practise
38 replies to this topic
#1 tuxianer
tuxianer
  • 34 posts
  • Interests:Programming, Computer, Photography, ?C's, Electric
    CFX 9850 GB+
    FX 9860 SD
Posted 11 February 2008 - 01:11 PM
hi,
i want to discover the I/O funktions and I have written this Code:
this ist the main:
	 unsigned int key;
	 Bdisp_AllClr_DDVRAM();
	 while(1){
		 GetKey(&key);
	  if (key == KEY_CHAR_1) {
		 PrintMini(0,0,(unsigned char*)"Taste 1",MINI_OVER);
		 Bdisp_AllClr_DD();
		 Bdisp_PutDisp_DD();
		 Bdisp_AllClr_VRAM();
	 Bdisp_AllClr_DD();
	 return 1;
bt when I press Key1 nothing happens.
#2 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 11 February 2008 - 03:46 PM
GetKey(&key);
Wait for a key to be pressed.
		 Bdisp_AllClr_DD();
		 Bdisp_PutDisp_DD();
//you can also do this:
		 Bdisp_PutDisp_DD();
If that key is <span class=1' />, draw the text "Taste 1"to VRAM, clear DD, copy VRAM to DD, clear VRAM. These steps are executed on a very short time (under 2ms).
Bdisp_AllClr_DD();
Whatever key you pressed, the screen will be cleared.
So, if you pressed <span class=1' />, the text appeared in only very short time that you can not notice.
Try this:
	 unsigned int key;
	 while(1){
	  GetKey(&key);
	  Bdisp_AllClr_DD();
		 Bdisp_AllClr_DD();
		 Bdisp_PutDisp_DD();
	 return 1;
#3 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 11 February 2008 - 04:46 PM
So it does'nt work also.
#4 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 11 February 2008 - 06:16 PM
	 unsigned int key;
	 while(1){
	  GetKey(&key);
	  Bdisp_AllClr_DD();
		 PrintMini(1,1,(unsigned char*)"Taste 1",MINI_OVER);
		 Bdisp_AllClr_DD();
		 Bdisp_PutDisp_DD();
	 return 1;
Try changing PrintMini(0,0,... to PrintMini(1,1). Point 0,0 does not exist on the pixel screen. Also you cleared the VRAM right after you drew something onto it.
#5 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 11 February 2008 - 06:43 PM
ok i will try it.
I use this tutorial: http://www.casiocalc...amp;#entry42808
there are also point 0,0 in the manual ist the display also descriped from 0 to 127 and I think with the Command Bdisp_PutDisp_DD(); I load the Ram to the DD...so why the screen will be cleared when I clear the ram? The data should be already in the DD. My Code should be do this:
Write data into ram-->clear DD-->put data to DD-->clear ram
#6 Fez
Fez
  • 162 posts
    Casio fx-9860G AU
Posted 12 February 2008 - 12:18 PM
I use the co ords 0, and 0 all the time and it works for me.
try this
int getkey;
	GetKey(&getkey);
	if(getkey == KEY_CHAR_1){
		PrintMini(0, 0, (unsigned char*)"Taste 1", MINI_OVER);
		Bdisp_PutDisp_DD();
		GetKey(&getkey);
This should wait for a button, and if it is 1, it will write taste 1 in 0, 0. Stick it on the screen and wait for a button. So the add in halts untill and button is pushed.
#7 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 17 February 2008 - 12:36 PM
does it wait for a key when i call getkey? So hangs the programm there until i press a key? or it only write the current key into a var? this code also doesn't work:
	 int getkey;
	 Bdisp_AllClr_DD();
	 while(1){
	 GetKey(&getkey);
	   Bdisp_AllClr_DD();
	 Bdisp_PutDisp_DD();
without the gk it works! When you add a Sleep(3000) at the and you can see, that the sreen will be cleared when i didn't press a key. So does a call of gk clear the screen?
#8 Fez
Fez
  • 162 posts
    Casio fx-9860G AU
Posted 17 February 2008 - 01:17 PM
getkey does not clear the screen. But it does stop the add in and wait for a button to be pressed. As soon as a button is pressed, it sticks the button value in the variable specified and continues the add in.
#9 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 17 February 2008 - 01:33 PM
hmm..ist there another solution which does not stop the adin? And which does not hang up the pogramm in generaly? Because when you call gk you cant't do things in the background.
#10 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 17 February 2008 - 03:06 PM
Gahh, this SDK stuff is already slipping out of my head. :banghead:
Oh yeah, there is another way to detect keys without stopping your addin. Here's an example:
while (!IsKeyDown(KEY_CTRL_EXE)) {
	// You code
	// continues as long as EXE is not pressed
#11 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 17 February 2008 - 03:31 PM
is there also any way to store the pressed key into a var without stopping the adin. I think this i very unintelligend and unefficient solved by casio. Is it possible to write a one function with ikeydown with the help of a pointer?
#12 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 17 February 2008 - 04:12 PM
There's suppose to be GetKeyWait, but I don't think there is any other way of storing the key pressed into a variable.
#13 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 17 February 2008 - 04:42 PM
But getkeywait also break the code and i hate this way of programming, when a program wait and you can't do anything in the background.
#14 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 17 February 2008 - 09:45 PM
so this seems to be the Solution for my Problem:
	int getkey;
	Bdisp_AllClr_DD();
	while(1){
		Bdisp_AllClr_DD();
		if (IsKeyDown(KEY_CHAR_1)) {
			  Bdisp_AllClr_DD();
			Bdisp_PutDisp_DD();
			Sleep(100);
But i have noticed that with the endless loop you can't get bay to the menu. Is the a solution for this problem? And whats the usage for getkeywait.
Another Question how can i mac a input? Should i do this manual a loop until exe is pressed? Or is the still a command for?
#15 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 18 February 2008 - 03:54 PM
You can download Revolution-FX and use the Reset_Calc() function to get back to the menu.
#16 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 18 February 2008 - 04:25 PM
ok and what ist with the inpt? scanf didn't work.
#17 Andreas B
Andreas B
  • 160 posts
    fx-9860G SD
Posted 18 February 2008 - 07:24 PM
There is no stdin/stdout or stderr on the calculator.
#18 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 18 February 2008 - 07:27 PM
so i have to programm this function by myselfe?
#19 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 19 February 2008 - 06:28 PM
so i habe tried to write a input code:
	unsigned int complete = 0;
	unsigned int print = 0;
	char input[100];
	Sleep(1000);
	 while(1){
		while(complete==0){
			if (IsKeyDown(KEY_CHAR_0)) {
				strcat(input, "0");
				print=1;
				while(!(IsKeyUp(KEY_CHAR_0)));
			else if (IsKeyDown(KEY_CHAR_1)) {
				strcat(input, "1");
				print=1;
				while(!(IsKeyUp(KEY_CHAR_1)));
			else if (IsKeyDown(KEY_CHAR_2)) {
				strcat(input, "2");
				print=1;
				while(!(IsKeyUp(KEY_CHAR_2)));
			if (print) {
				print=0;
				PrintMini(0,0,(unsigned char*)input,MINI_OVER);
				Bdisp_AllClr_DD();
				   Bdisp_PutDisp_DD();
			if (IsKeyDown(KEY_CTRL_EXE)) {
				complete=1;
		PrintMini(0,0,(unsigned char*)"Complete",MINI_OVER);
		 Bdisp_AllClr_DD();
		Bdisp_PutDisp_DD();
is there realy no easier way?
#20 BiTwhise
BiTwhise
    Casio Overgod
  • 627 posts
  • Interests:Programming, games, consoles, martial arts
    FX9700WE, CFX9970G, AFX2.0, Classpad 300
Posted 19 February 2008 - 07:59 PM
I've not done any programming on the 9860 (I assume this is your calculator), however the input code could be simplified drastically.
Keep two arrays of state for all the keys you're interested in.
One will be the current state, the other the previous.
Every iteration, you assign the current to the previous, and update the current to the new state.
Now, you can test if a key was just pressed by testing if it was up in the previous state and down in the current state. Same, but opposite, for wethere a key was just released.
That gets rid of your "while (!IsKeyUp(...))"
Next, you probably want to keep an array mapping from key to character.
If you have modifier keys, you can keep multiple character mappings per key.
Once you have that, you can simply loop over the keys of interest, test if they were just pressed (or released), read the mapping, and output it to your buffer.
You'll obvoiusly need to handle special keys, like backspace or exe, seperately.
I'm surprised there isn't any functionality like this in the SDK already though...
#21 BiTwhise
BiTwhise
    Casio Overgod
  • 627 posts
Posted 19 February 2008 - 08:28 PM
I knocked up some Win32 console app code as proof of concept.
It demonstrates basic key mapping, using a modifier key, and escaping the input.
It's obviously far from complete. You'd need to handle backspace, tabs, and other things, but it was just knocked up in 10 minutes.
My KeyState function is equivalent to the IsKeyDown sdk function.
Now, GetAsyncKeyState already tells you whether a key was just pressed or not, but this is just to show how you can work without that.
You'd probably also want to wrap this up more nicely :)
#include <iostream>
#include <windows.h>
bool KeyState(int key)
	return (GetAsyncKeyState(key) & 0x8000) != 0;
struct Key
	int scanCode;   // scan code to test
	char outNormal; // normal output
	char outShift;  // shift modified output
int main()
	int const numKeys = 27;
	// Keys
	Key keys[numKeys] =
		{'A', 'a', 'A'},
		{'B', 'b', 'B'},
		{'C', 'c', 'C'},
		{'D', 'd', 'D'},
		{'E', 'e', 'E'},
		{'F', 'f', 'F'},
		{'G', 'g', 'G'},
		{'H', 'h', 'H'},
		{'I', 'i', 'I'},
		{'J', 'j', 'J'},
		{'K', 'k', 'K'},
		{'L', 'l', 'L'},
		{'M', 'm', 'M'},
		{'N', 'n', 'N'},
		{'O', 'o', 'O'},
		{'P', 'p', 'P'},
		{'Q', 'q', 'Q'},
		{'R', 'r', 'R'},
		{'S', 's', 'S'},
		{'T', 't', 'T'},
		{'U', 'u', 'U'},
		{'V', 'v', 'V'},
		{'W', 'w', 'W'},
		{'X', 'x', 'X'},
		{'Y', 'y', 'Y'},
		{'Z', 'z', 'Z'},
	// Buffers for key state
	bool state1[numKeys] = {false,};
	bool state2[numKeys] = {false,};
	// Pointers that alternate buffers
	bool* prevState = state1;
	bool* currState = state2;
	while (true)
		// Switch buffers
		std::swap(prevState, currState);
		// Update current buffer
		for (int i = 0; i < numKeys; ++i)
			currState[i] = KeyState(keys[i].scanCode);
		// Read modifier key (SHIFT)
		bool shift = KeyState(VK_SHIFT);
		// Read key states and print
			if (currState[i] && !prevState[i])
				std::cout << (shift ? keys[i].outShift : keys[i].outNormal);
				break;
		// Quit when ESC is pressed
		if (KeyState(VK_ESCAPE))
			break;
	return 0;
#22 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 21 February 2008 - 08:31 PM
ok i can try it...but is there raly no input function? so i think it is a good idea to include this in the Revolution-FX library or is this allready done?
#23 Andreas B
Andreas B
  • 160 posts
    fx-9860G SD
Posted 21 February 2008 - 11:58 PM
Why don't you check? The one in revolution-fx is blocking and inefficient.
#24 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 22 February 2008 - 08:51 PM
Yeah, Revolution-FX has an input function: string_input()
Try looking at the Revolution-FX documentation: http://revolution-fx...ml#string_input
That wasnt helpful. You could have pointed him towards the documentation and let him read it. That's what it's there for.
Judging from his post: http://www.casiocalc...=...ost&p=44244, what he want's is to get user input. So... what's your point? Blocking?: it's just like scanf() and inefficient?: It does what it's meant to do: get a string from the user.
#25 BiTwhise
BiTwhise
    Casio Overgod
  • 627 posts
Posted 22 February 2008 - 09:23 PM
If you're having problems writing this kind of function yourself, and string_input does what you need, I think you should see where you get with that.
I had a quick look at the it, and you should be aware there's no buffer overflow protection in it..
kukalc, from the source file it looks like you're the author, so I'd suggest you change your API to include maximum input length. Easy to fix and such an unecessary voulnerability to have in there.
#26 Andreas B
Andreas B
  • 160 posts
    fx-9860G SD
Posted 22 February 2008 - 09:52 PM
I assumed he would be able to read/find documentation himself, as he knows the website for rev-fx.
It was unclear if he wanted to be able to do other stuff while reading input.
My point is, to cite myself: "[string_input] is blocking and inefficient". By 'inefficient' (in programming context), we usually mean big and/or slow. Example of better solution; http://casio.pastebin.com/f2ef7343f (does not use PrintMini, I know).
#27 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 23 February 2008 - 05:54 PM
with wich key can i leve the input function...exe doesn't work
	char input[100];
	Sleep(1000);
	while(1){
		string_input(1,1,input);
		Bdisp_AllClr_DD();
		   Bdisp_PutDisp_DD();
		Sleep(1000);
whe i press exe it delete the screen but there is no sleep or so...
#28 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 24 February 2008 - 12:44 PM
i have tried this:
struct Key
	// Keys
	Key keys[numKeys] =
		{KEY_CHAR_DP, ' ', ' '},
		{KEY_CHAR_XTT, 'a', 'A'},
		{KEY_CHAR_LOG, 'b', 'B'},
		{KEY_CHAR_LN, 'c', 'C'},
		{KEY_CHAR_SIN, 'd', 'D'},
		{KEY_CHAR_COS, 'e', 'E'},
		{KEY_CHAR_TAN, 'f', 'F'},
		{KEY_CHAR_FRAC, 'g', 'G'},
		{KEY_CHAR_FD, 'h', 'H'},
		{KEY_CHAR_LPAR, 'i', 'I'},
		{KEY_CHAR_RPAR, 'j', 'J'},
		{KEY_CHAR_COMMA, 'k', 'K'},
		{KEY_CHAR_STORE, 'l', 'L'},
		{KEY_CHAR_7, 'm', 'M'},
		{KEY_CHAR_8, 'n', 'N'},
		{KEY_CHAR_9, 'o', 'O'},
		{KEY_CHAR_4, 'p', 'P'},
		{KEY_CHAR_5, 'q', 'Q'},
		{KEY_CHAR_6, 'r', 'R'},
		{KEY_CHAR_MULT, 's', 'S'},
		{KEY_CHAR_DIV, 't', 'T'},
		{KEY_CHAR_1, 'u', 'U'},
		{KEY_CHAR_2, 'v', 'V'},
		{KEY_CHAR_3, 'w', 'W'},
		{KEY_CHAR_PLUS, 'x', 'X'},
		{KEY_CHAR_MINUS, 'y', 'Y'},
		{KEY_CHAR_0, 'z', 'Z'},
	int State1[numKeys] = { 0 };
	int State2[numKeys] = { 0 };
	int Shift = 0;
	char Input[100] = {""};
	int* prevState = State1;
	int* currState = State2;
	while(1) {
			currState[i] = IsKeyDown(keys[i].scanCode);
		else if (IsKeyDown(KEY_CTRL_SHIFT)) {
			if(Shift==0) {
				Shift=1;
			}else{
				Shift=0;
			while(!(IsKeyUp(KEY_CTRL_SHIFT)));
				if(Shift) {
					strcat(Input, keys[i].outShift);
				}else{
					strcat(Input, keys[i].outNormal);
				break;
			break;
and get those Errors:
) : C2500 (E) Illegal token "}"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(68) : C2500 (E) Illegal token ","
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(71) : C2500 (E) Illegal token "int"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(71) : C2225 (E) Undeclared name "State0"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(71) : C2233 (E) Illegal array reference
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(71) : C2500 (E) Illegal token "{"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(71) : C2500 (E) Illegal token "}"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(72) : C2500 (E) Illegal token "int"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(72) : C2225 (E) Undeclared name "State1"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(72) : C2233 (E) Illegal array reference
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(72) : C2500 (E) Illegal token "{"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(72) : C2500 (E) Illegal token "}"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(73) : C2500 (E) Illegal token "int"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(73) : C2225 (E) Undeclared name "Shift"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(73) : C2220 (E) Modifiable lvalue required for "="
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(74) : C2500 (E) Illegal token "char"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(74) : C2225 (E) Undeclared name "Input"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(74) : C2233 (E) Illegal array reference
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(74) : C2500 (E) Illegal token "{"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(74) : C2500 (E) Illegal token "}"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(75) : C2500 (E) Illegal token "int"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(75) : C2225 (E) Undeclared name "prevState"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(75) : C2208 (E) Pointer required for "*"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(75) : C2225 (E) Undeclared name "state1"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(75) : C2220 (E) Modifiable lvalue required for "="
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(76) : C2500 (E) Illegal token "int"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(76) : C2225 (E) Undeclared name "currState"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(76) : C2208 (E) Pointer required for "*"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(76) : C2225 (E) Undeclared name "state2"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(76) : C2220 (E) Modifiable lvalue required for "="
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(79) : C2500 (E) Illegal token ":"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(81) : C2500 (E) Illegal token "int"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(81) : C2225 (E) Undeclared name "i"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(83) : C2233 (E) Illegal array reference
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(83) : C2203 (E) Illegal member reference for "."
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(87) : C2500 (E) Illegal token "else"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(97) : C2500 (E) Illegal token "int"
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(99) : C2233 (E) Illegal array reference
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(102) : C2233 (E) Illegal array reference
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(102) : C2203 (E) Illegal member reference for "."
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(104) : C2233 (E) Illegal array reference
C:\Dokumente und Einstellungen\tuxianer\Eigene Dateien\CASIO\fx-9860G SDK\Eingabe\Eingabe.c(104) : C2203 (E) Illegal member reference for "."
I take int instead of Bool, because bool also brings an error...
#29 Andreas B
Andreas B
  • 160 posts
    fx-9860G SD
Posted 24 February 2008 - 07:17 PM
At the line with "{KEY_CHAR_0, 'z', 'Z'},", you can not end with a comma.Ending the array with
should work.
You may not have std::swap(), or strcat().
Check my last post for link to input code that uses GetKey(). You supply the row/column to show the input string, the buffer to get the data in, and the length of the buffer.
#30 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 24 February 2008 - 08:16 PM
yes that ws realy an error, but the other errors are quit there...
#31 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 26 February 2008 - 05:02 PM
or can it be an encoding error of the text?
#32 BiTwhise
BiTwhise
    Casio Overgod
  • 627 posts
Posted 26 February 2008 - 05:30 PM
I don't quite understand what you're trying to say here.
It looks to me like you're struggling with some basic syntax and programming concepts.
If you're new to programming, the calculator SDK might not be a particularly good starting point.
Go out and do some generic C/C++ programming tutorials.
Get familiar with the process of programming - the compiler, the linker, and the debugger.
Learn to recognize common syntax errors.
A basic environment (editor + command line tools) will put you right in the trenches with the compiler and linker and force you to understand how they work.
Go with this if you want to learn and understand everything from the ground up.
A good IDE will introduce you to project structure and working with an integrated debugger.
Go with this if you want to get up and running with the tools quickly, and concentrate on the language and the operation of the software.
An embedded platform, like the calculator, will drop you right in with cross compilation, poor debugging, lack of libraries, and alot of other pain.
On the plus side, it's a finite environment - you can easilly learn almost all there is to learn about the platform. The OS and the SKD is usually quite small. This focused feeling might give you a sense of mastery and completeness.
By the way, for syntax errors, always look at the first error in your output as other errors will quite often follow from it.
#33 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 26 February 2008 - 07:32 PM
I'am able to programm I think so. And I also wored with C scince a while. The only new thing for me is the Casio IDE. But in this case I think the is something wrong with the IDE. When I clik on the first Error there Appear a messag, that the file doesn't exist. Some Errors I got fixed but not all.
#34 2072
2072
    Casio over god
  • Admin
  • 1565 posts
Posted 27 February 2008 - 02:17 AM
I don't know C++ but in C you can't initialize tables with a variable length.
so your numKeys should be a preprocessor macro:
#define numKeys 27
then the line:
Key keys[numKeys] =
should be replaced by
struct Key keys[numKeys] =
On line 61 there is an 'else' that is not related to an if....
in your for loop 'i' is declared several times in the same block... just put a "int i = 0" at the start of your AddIn_main function and remove the 'int' before the 'i' in the for loops...
there are othere errors such as the arguments of strcat those must be pointers....
I think you shoud do some C / C++ tutorials before continuing.
#35 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 08 March 2008 - 10:17 PM
Ok i have a a working code:
	  int Status_Alt[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
	  int Status_Neu[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
	  char Gross[] = {' ', 'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z'};
	  char Zahlen[] = {'7', '8', '9', '4', '5', '6', 'x', '/', '1', '2', '3', '+', '-', '0'};
	  int Code[] = {KEY_CHAR_DP,KEY_CTRL_XTT,KEY_CHAR_LOG,KEY_CHAR_LN,KEY_CHAR_SIN,KEY_CHAR_COS,KEY
  _CHAR_TAN,KEY_CHAR_FRAC,KEY_CTRL_FD,KEY_CHAR_LPAR,KEY_CHAR_RPAR,KEY_CHAR_CO
MMA,K
 E
  Y_CHAR_STORE,KEY_CHAR_7,KEY_CHAR_8,KEY_CHAR_9,KEY_CHAR_4,KEY_CHAR_5,KEY_CHA
R_6,K
 E
  Y_CHAR_MULT,KEY_CHAR_DIV,KEY_CHAR_1,KEY_CHAR_2,KEY_CHAR_3,KEY_CHAR_PLUS,KEY
_CHAR
 _
  MINUS,KEY_CHAR_0};
	  int i;
	  int Alpha = 0;
	  int Stelle=0;
	  int laenge;
	  int Exp;
	  while(1){
		  if(IsKeyDown(KEY_CTRL_ALPHA)) {
			  if(Alpha==0) {
				  Alpha=1;
			  } else {
				  Alpha=0;
			  while(!IsKeyUp(KEY_CTRL_ALPHA));
		  for (i=0; i<27; ++i) {
			  Status_Alt[i]=Status_Neu[i];
		  for(i=0; i<27; ++i) {
			  Status_Neu[i]=IsKeyDown(Code[i]);
		  if(Alpha) {
				  if((Status_Alt[i]==0) && (Status_Neu[i]==1)) {
					  input[Stelle]=Gross[i];
					  Stelle++;
		  }else{
			  for(i=13; i<27; ++i) {
					  input[Stelle]=Zahlen[i-13];
					  Stelle++;
			   Nummer=atoi(Input);
		  if(IsKeyDown(KEY_CTRL_DEL) ){
			  Stelle--;
			  input[Stelle] =  ' ';
			  while(!IsKeyUp(KEY_CTRL_DEL)) {
		   Bdisp_AllClr_DD();
		   Bdisp_PutDisp_DD();
#36 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 09 March 2008 - 12:01 AM
Cool, good job on getting it to work. :)
#37 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 09 March 2008 - 11:06 AM
I have put it into a function code come next if you want you can add it to revolution fx.
void Input_Char (int x, int y, char * input)
	 int status_old[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
	 int status_new[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
	 char big_letter[] = {' ', 'A', 'B', 'C', 'D', 'E', 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S', 'T', 'U', 'V', 'W', 'X', 'Y', 'Z'};
	 int code[] = {KEY_CHAR_DP,KEY_CTRL_XTT,KEY_CHAR_LOG,KEY_CHAR_LN,KEY_CHAR_SIN,KEY_CHAR_COS,KEY
 _CHAR_TAN,KEY_CHAR_FRAC,KEY_CTRL_FD,KEY_CHAR_LPAR,KEY_CHAR_RPAR,KEY_CHAR_COMMA,K
E
 Y_CHAR_STORE,KEY_CHAR_7,KEY_CHAR_8,KEY_CHAR_9,KEY_CHAR_4,KEY_CHAR_5,KEY_CHAR_6,K
E
 Y_CHAR_MULT,KEY_CHAR_DIV,KEY_CHAR_1,KEY_CHAR_2,KEY_CHAR_3,KEY_CHAR_PLUS,KEY_CHAR
_
 MINUS,KEY_CHAR_0};
	 int i;
	 int position=0;
	 int print;
	 while(!IsKeyDown(KEY_CTRL_EXE)){
		 if(position < 32) {
				 status_old[i]=status_new[i];
				 status_new[i]=IsKeyDown(code[i]);
				 if((status_old[i]==0) && (status_new[i]==1)) {
						input[position]=big_letter[i];
					 position++;
					 print=1;
		 if (position>0) {
				 position--;
				 input[position] =  ' ';
				 print=1;
				 while(!IsKeyUp(KEY_CTRL_DEL));
		 if(print==1) {
			 PrintMini(y,x,(unsigned char*)input,MINI_OVER);
				Bdisp_AllClr_DD();
			 Bdisp_PutDisp_DD();
			 print=0;
 float Input_Num (int x, int y)
	 int status_old[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
	 int status_new[] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
	 char numbers[] = {'.', '7', '8', '9', '4', '5', '6', 'x', '/', '1', '2', '3', '+', '-', '0'};
	 int code[] = {KEY_CHAR_DP,KEY_CHAR_7,KEY_CHAR_8,KEY_CHAR_9,KEY_CHAR_4,KEY_CHAR_5,KEY_CHAR_6,K
 EY_CHAR_MULT,KEY_CHAR_DIV,KEY_CHAR_1,KEY_CHAR_2,KEY_CHAR_3,KEY_CHAR_PLUS,KEY_CHA
R
 _MINUS,KEY_CHAR_0};
	 int i;
	 int position=0;
	 int number;
	 int print;
	 char input[] = {' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ', ' ',  ' ', ' '};
		 if(position < 32) {
				for (i=0; i<15; ++i) {
			 for(i=0; i<15; ++i) {
						input[position]=numbers[i];
					 position++;
					 print=1;
		 if (position>0) {
				 position--;
				 print=1;
		 if(print==1) {
				Bdisp_AllClr_DD();
			 Bdisp_PutDisp_DD();
			 print=0;
			 number=atoi(input);
	 return number;
#38 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 11 March 2008 - 01:30 PM
Cool, I'll add it when I get the time and I'll give you proper credit. :)
#39 tuxianer
tuxianer
  • 34 posts
    CFX 9850 GB+
    FX 9860 SD
Posted 11 March 2008 - 02:53 PM
NExt Time I will put the arrays into structs and add small letters. And i will try to return an array by the char function like i have done it with the num. I think this is also possible with structs.
