Help With A Fx4500p
Guest_oziworks_*
Posted 04 March 2008 - 01:55 AM
Cheers
Glenn
glenn AT wheelsmith.com.au
Posted 04 March 2008 - 04:13 AM
Is the calculator still functioning? It still turns on and you are able to access the program?
Also, are you still able to view the code contents? If so, does the calculator have a link port to connect to another calculator or a PC?
Guest_oziworks_*
Posted 04 March 2008 - 04:58 AM
Cheers
Glenn
Posted 04 March 2008 - 10:43 AM
another FX-4500P(A) or to modify it for another calculator. It uses a BASIC like
formula programming language.
Posted 04 March 2008 - 10:52 AM
The calculator is still functioning OK. I can turn it on and use the functions / programs that are installed. But the unit does not appear to have an external port to allow anything to plug in. It has a silver metal rear cover but I'm not sure if there is a port underneath that.
Cheers
Glenn
Hi Glenn,
I've got an FX-4500P in front of me right now!
Unfortunately, there is no way I know of to upload the program(s) to another unit; i.e., you can't plug in any cable.
It's a long time since I've actually used one for executing programs, but what I used to do was:
1) Press the 'FILE' key until the required program name was shown
2) Use the cursor keys to display each line of the program
3) Write down each line of the program
I've just done it on mine and seen that my mortgage calculator program that I wrote about 10 years ago is corrupt
People have it so easy nowadays, with cables and memory cards and stuff
I'm now really starting to feel quite nostalgic.
I have an electronic copy of the manual somewhere - Just let me know if you think it might be of help and I'll dig it out for you.
David.
Guest_ERIC_*
Posted 18 September 2009 - 06:15 AM
I forget how to do it.
Please tell me
Posted 18 September 2009 - 10:52 AM
SHIFT + ALPHA for the permanent alpha mode.
Guest_peter donoghue_*
Posted 17 January 2010 - 10:40 PM
Press AC FILE
then press (arrow down) to view the contents...
I wish somebody could start a database for all our Programs..
I have lost mine and had to start over...had a difficult time even remembering hot to program the Calculator..
Guest_Cedfelix_*
Posted 29 January 2010 - 11:21 PM
Guest_Maqs_*
