Unoccupied Flash Sectors Fx9860g Os 1.05
Posted 05 June 2008 - 05:43 PM
I'd like to use unoccupied OS flash sectors (about 400kB) as extra storage memory on FX9860G.
This function should be as OS-independent as possible. Hence it would be fine to know the size of memory the different OS versions don't use.
For V1.03 and V1.04 the situation is clear, both have 7 unoccupied 64kB-sectors.
Does anybody run a FX9860G with OS version 1.05?
If so, I would appreciate it, if the owner would download INSIGHT and run the flash-map-function, please. I need to know the number of contiguous zeros beginning in the 4th line of the displayed flash-map. A captured display would be perfect, of course.
I hope somebody could help me.
Posted 06 June 2008 - 10:39 PM
there are 7 zeros.
the insert image is not working for me, I'll send you screen shot as soon as possible.
Posted 07 June 2008 - 03:37 AM
Thanks a lot. That's exactly the information I have been looking for.
Posted 07 June 2008 - 12:30 PM
Regards.
Posted 21 June 2008 - 07:32 AM
No problem. I really admirer your efforts .
Regards.
Another query: could you calculate the following checksum on your FX9860G OS 1.05, please?
int work;
int*addr;
work = 0;
addr = (int*)0x80000000;
while ((int)addr<0x80190000){
work ^= *addr;
addr++;
(I intend to use this checksum to perform an OS-independent check for FX9860G's OS integrity)
Thanks for your efforts!
Posted 21 June 2008 - 12:15 PM
I feel glad if I can help.
I?ve bought fx-9860 for my collection(it has a great potentials), actually I don?t use it now but; I?m intending to as soon as I complete my thesis.
Your checksum program is written in C, as far as I know we can?t write C progs. directly to fx-9860G. If you instruct me, ill be glad to help. Please don?t hesitate to send an inquiry; this will make me more familiar with my fx-9860G.
Regards.
Posted 21 June 2008 - 02:33 PM
Posted 21 June 2008 - 04:04 PM
The checksum is (0xD4632D3D).
By the way did you use the casio SDK or what? I need to know please.
Have a nice day.
Posted 21 June 2008 - 04:19 PM
Posted 21 June 2008 - 04:24 PM
Me? The CASIO SDK could be used for that, but I used GCC and some custom tools (as I use <{GNULINUX}> instead of Windows).Hi,
Have a nice day.
Posted 21 June 2008 - 04:55 PM
Posted 25 July 2008 - 02:51 PM
It happened to my HP ( Everyone was warned to backup the newly to be used space though ).
Posted 25 July 2008 - 04:51 PM
Even with known OS versions (1.02..1.05) it checks for the count of unoccupied sectors and complains if it is not as it should be. With INSIGHT's flash map, it is possible to check unoccupied sectors manually, if you want to be careful.
Independent of the count of unused sectors, an OS update destroys any INSIGHT ESM data. The FX 9860G OS update erases everything between flash address 0 and 0x26FFFF. The storage memory survives.
