Goto Variable
#1 ericlegomeer
ericlegomeer
  • 7 posts
    fx-82MS
    fx-82ES
    fx-9860G
Posted 31 August 2008 - 10:37 AM
Yesterday I made an account on this forum because I had a problem... After some thinking I solved it myself... Now I've got a new problem and I hope someone can help me.
What I want to do is something like this:
1 :arrow: A :newline:
Goto 2 :newline:
Lbl 1 :newline:
Locate 1,1,"This is label 1" :newline:
Lbl 2 :newline:
Goto A :newline:
The problem is that you can also use 'A' as a label name. So you'd get an Go Error when you'd start this code.
Now what you could do is make a long piece a code which will check if the variable A is 1,2,3... or 9 and then go to that label, but it has to be easier... Does someone know how??
Eric
PS is there somewhere a switch statement in the program functions?
#2 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 01 September 2008 - 09:56 PM
Hello ericlegomeer and welcome to the forum! :D
According to your other thread, you have solved this problem, right? If so, you may want to post your solution here so others who are curious can learn also.
#3 ericlegomeer
ericlegomeer
  • 7 posts
    fx-82MS
    fx-82ES
    fx-9860G
Posted 02 September 2008 - 05:40 AM
Well, the only answer I could come up with is something like this:
If A=1
Then Goto 1
Else If A=2
Then Goto 2
Else If A=3
Then Goto 3
But there has to be a better way...
Maybe I can store the number somewhere else, and then recall it :greengrin: ...
I'll keep trying, when I have finished it I'll post the answer, but for now on it's just a log piece a code...
Eric
#4 Somelauw
Somelauw
  • 14 posts
    Casio CFX-9850GC PLUS
Posted 08 September 2008 - 02:43 PM
Best way (in my opinion):
while 1 //main
while a = 1
whileend
while a = 2
whileend
a = 1
whileend //to main
I don't know exactly what you want to do. But I like to avoid goto and lbls as much as possible because they confuse the heck outa me.
