Hello all,
I've managed too add text reader v 2. to my calculator and have put two text files into my storage memory to test the program. I can open up the initial text file, but i can't for the life of me, figure out how to switch to the other text file (get back to the menu of TXT reader which allows me to switch between text files). Menu simply sends me back to the main menu, and then re-selecting the program just sends me right back into the previously opened text file. EXE as with EXIT (+shift) while in text file just does nothing. So I can only read one text file. The only way too switch text files for me is to go into memory and delete the text file I'm viewing and then select another, which isnt very useful.
I have a fx-9860G au, is text reader not viable with that version of calculator? If not are there any programs that perform the same duty and work on the AU?
Thanks in advance for any help!
~Laurence
![Photo](https://secure.gravatar.com/avatar/e7956e55de1b745bb1e743a76c9521ac?s=100&d=https%3A%2F%2Fcommunity.casiocalc.org%2Fdot%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Problem With Text Reader
Laurence
, Sep 22 2008 07:47 AM
