Is it possible to change or specify the color text will be display on the CFX models? In text mode, text is displayed with either the Locate statement, or at current screen location using it in quotes. In grahics modes text is placed on the screen using the text statement.
I really would like to be able to place text in different colors on the graphics screen. Anyone can help?
![Photo](https://secure.gravatar.com/avatar/4f0eb4ecfe78dddc52e64068d88daa83?s=100&d=https%3A%2F%2Fcommunity.casiocalc.org%2Fdot%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Changing Text Color On Cfx
dschlic1
, Sep 27 2008 02:10 AM
Posted 27 September 2008 - 02:10 AM
Posted 27 September 2008 - 05:23 PM
I don't remember if the CFX can change text color. But you can try out yourself, by putting a color command in front of Locate (such as Blue or Green). If it doesn't work, then I guess it isn't possible to change the text color.
