I connect my Calculator using the USB cable and then sometimes it doesn't automatically create a connection so I go into Communications and select the second icon from the left, the picture of the calculator with an arrow towards it. I open FA-CP1 but on the left it doesnt have ClassPad 1 or what ever it is supposed to have. I think after that your supposed to click, Handheld Assist ---> Install Ad-in To CLasspads.
Any help please?
Using Fa-cp1 To Install Programs Onto Classpad 330
tim410au
, Oct 25 2008 02:36 AM
Posted 25 October 2008 - 02:36 AM
Guest_Black Knight_*
Posted 16 February 2010 - 07:52 AM
Any help please?
you go to setup, Open Setup Menu, and were it says cable type you have to change it from 3 pin to USB
if this doesnt work than im not sure wat the problem is
