Fx-9750g Plus And Os
7 replies to this topic
#1 cb951303
cb951303
  • 4 posts
Posted 18 December 2008 - 05:20 PM
If I buy this product will I be able to update the OS inside with the jack-to-serial pc link cable? If so, which application can use?
Thanks very much
#2 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 18 December 2008 - 06:13 PM
Hello cb951303 and welcome to the UCF! :D
Sorry no, the fx-9750G is not OS upgradable.
#3 cb951303
cb951303
  • 4 posts
Posted 18 December 2008 - 06:45 PM
too bad :/ thanks for reply
Edited by 2072, 22 December 2008 - 12:13 AM.
#4 cb951303
cb951303
  • 4 posts
Posted 18 December 2008 - 09:27 PM
I can't find the technical specs of thhis calculator. How much EEPROM does it have to store text data and formulas?
Is it possible to write a text file in windows and then transfer it to the fx-9750g via link cable?
thanks again
#5 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 19 December 2008 - 05:54 AM
The fx-9750G Plus only has, I think 64KB of "RAM". You can't transfer a text file to the fx-9750G per se, but you can store notes within a BASIC program.
#6 Guest_3298_*
Guest_3298_*
  • Guests
Posted 19 December 2008 - 10:47 AM
64 KB? My one has only 32KB (28 for user).
You only can update the OS by opening the calculator. But you would have to write the new OS yourself. Martin Poupe (see his website ) has done it for th CFX 9850 G, but the hardware is slightly different (e.g. color screen), so his OS needn't run on the fx 9750 G Plus.
#7 cb951303
cb951303
  • 4 posts
Posted 19 December 2008 - 12:35 PM
maybe we should start exchanging rom hex dumps so people with calculators with out a usb connection would get the latest software :)
does anyone know what kind of ROM is used in these cals so that I can find an appropriate programmer.
thanks
#8 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 19 December 2008 - 11:48 PM
Well, that would be nice, but what's the point. No updates exists for the fx-9750G. You can't simply take an OS from a calculator that has USB (ex. fx-9860) and it expect it to work in the fx-9750G.
