Hi
I'm relatively new to programming, though I have done very basic programs for my calculator
I'm trying to write a program that returns with the simplification of surds
e.g.
√128 simplifies to 8√2
The formula that I want to use for this is √(a/b)=c which translates into c√b
i.e.
in the above example 128=a and 8√2 is c√b
What I plan to do is something like this:
?->a
1->b
if √(a/b) has no decimal places
then √(a/b)->c
otherwise b++
Then I want it to display is in the form of c√b
Will this work?:
disp a_"√"c_ work
Basically I need help with the decimal places and the display area of this program
Any help is appreciated
Help With A Program For Surds - Fx-9750 Plus
Deathblake
, Feb 19 2009 03:49 AM
Posted 19 February 2009 - 03:49 AM
Posted 19 February 2009 - 04:57 PM
Hello,
I think you're going to have to factorise the input number in order to find its square factors.
for example, factoring 128 gives 2, 7 times (ie 2^7 = 128). Therefore, 128 = 2*(2^6), so sqrt(128) = 2^3*sqrt(2) = 8sqrt(2)
another, sqrt(90) ?
90 = 2*3*3*5. since 3 occurs twice we have the root as 3*sqrt(2*5) = 3sqrt(10).
For small(ish) integers you could factor by trial division.
another, sqrt(90) ?
Edited by Hugh, 19 February 2009 - 04:58 PM.
Posted 19 February 2009 - 07:16 PM
Thanks
This is (basically) the way we have manually been doing it in class.
I've been sleeping on the program, and here is what I have come up with
?->A
1->B
While (√((A/B)-Int (√A/B))!=0
Do
B+1->B
WhileEnd
√(A/B)->C
C_
H_
_ is the little triangle right?
The only problem is that I can only execute it once, because after it returns my numbers it causes a syntax error
EDIT: I've been playing around with it today and this is what I have come up with
[codebox]Lbl 1
?->A
If A=0
Then Goto 2 // The forumula doesn't handle 0 as an input
IfEnd
1->B
Do
B+1->B
WhileEnd
√(A/B)->C // The basic function is now complete, the following is now to calculate how to display
Int (logB+1)->D // D=number of digits in B
Int (lobC+1)->E
22-(D+E+1)->F
22-(D+1)->G
22-D->H
Locate F,6,C
Locate G,6,"√"
Locate H,6,B
Goto 1
Lbl 2
Locate 21,6,0
Goto 1[/codebox]
What do I add to make the Exit key Exit the program and return to normal RUN mode?
?->A
1->B
Do
B+1->B
WhileEnd
√(A/B)->C
C_
H_
[codebox]Lbl 1
?->A
If A=0
IfEnd
1->B
Do
B+1->B
WhileEnd
Int (lobC+1)->E
22-(D+E+1)->F
22-(D+1)->G
22-D->H
Locate F,6,C
Locate G,6,"√"
Locate H,6,B
Goto 1
Lbl 2
Locate 21,6,0
Goto 1[/codebox]
Edited by Deathblake, 20 February 2009 - 06:24 AM.
Posted 21 February 2009 - 04:15 PM
Hello,
Your method will work, although i don't know the answer to your programming question for this language. I don't use the built-in programming system at all.
What your method is doing is trying to divide out the non-square factors leaving the square factor remaining (if any). Consequently your value for B will range from 1 to A and will get quite slow if A is large.
As another approach, you could try to divide out the square factor. Here is the general idea:
if A has a square factor, it has a factor b <= sqrt(A).
loop b from 2 to sqrt(A)
if b^2 exactly divides A, then multiply b into the square factor (to return) and divide A by b^2 continue
otherwise increase b by 1 and continue.
Here's some LUA code that does what im talking about, maybe you can recode it for your casio.
[codebox]function surd(A)
sq = 1 -- will be the square factor on return
N = math.sqrt(A)
b = 2
while b <= N
do
b2 = b*b
q = math.floor(A/b2) -- INT of A/b^2
if A == q*b2 -- is it a factor?
then
-- yes, keep the square factor and reduce A
sq = sq * b;
A = q
else
-- otherwise move on to next b
b = b + 1
end
end
-- return two values, the square factor and reduced A
return sq, A
end
[/codebox]
Good Luck!
N = math.sqrt(A)
b = 2
while b <= N
do
b2 = b*b
then
sq = sq * b;
A = q
else
b = b + 1
end
end
return sq, A
end
[/codebox]
Good Luck!
Posted 26 February 2009 - 09:22 AM
Thanks
While I don't get how your while loop works, I understand the basic idea behind it
However, to simplify fully, you need to make b an INT of Sqrt a, and decrease it each time
Here is my amended (and hopefully final) code:
[codebox]Lbl 1
?->A
If A=0
IfEnd
Int √A->B
While ((A/B^2 -Int A/B^2)!=0
Do
B-1->B
WhileEnd
A/B^2->C // The basic function is now complete, the following is now to calculate how to display
Int (lobC+1)->E
22-(D+E+1)->F
22-(E+1)->G
22-E->H
Locate F,6,B
Locate G,6,"√"
Locate H,6,C
Goto 1
Lbl 2
Locate 19,6,1
Locate 20,6,"√"
Locate 21,6,0
Goto 1[/codebox]
[codebox]Lbl 1
?->A
If A=0
IfEnd
Int √A->B
Do
B-1->B
WhileEnd
Int (lobC+1)->E
22-(D+E+1)->F
22-(E+1)->G
22-E->H
Locate F,6,B
Locate G,6,"√"
Locate H,6,C
Goto 1
Lbl 2
Locate 19,6,1
Locate 20,6,"√"
Locate 21,6,0
Goto 1[/codebox]
Posted 15 March 2009 - 08:09 PM
Lbl 1?->AIf A=0Then Goto 2 // The forumula doesn't handle 0 as an inputIfEndInt √A->BWhile ((A/B^2 -Int A/B^2)!=0DoB-1->BWhileEndA/B^2->C // The basic function is now complete, the following is now to calculate how to displayInt (logB+1)->D // D=number of digits in BInt (lobC+1)->E22-(D+E+1)->F22-(E+1)->G22-E->HLocate F,6,BLocate G,6,"√"Locate H,6,CGoto 1Lbl 2Locate 19,6,1Locate 20,6,"√"Locate 21,6,0Goto 1
Hi there, I tried your code above and it did not work flawlessly as expected. I have improved upon your program and came up with the following that is foolsproof. (NB. I have used different variables but this doesnt matter)
Lbl 11->A?->XRoot(X)->KFor 2->I To (Int K)If (X/I^2)=Int (X/I^2)ThenAxI->I(X/(I^2))->XIfEndNextInt (Log A+1)->DInt (Log X+1)->E22-(D+E+1)->F22-(E+1)->G22-E->HLocate F,6,ALocate G,6,"Root"Locate H,6,XGoto 1
You may have noticed that I use some of your code in the last few lines
If this code does not work for you or you have a question to ask me, then simply PM me or reply here.
Hope that this helps,
mintsmike
