Fx 1.0 Plus, Some Key Not Responding! Broken/jammed?
8 replies to this topic
#1 johnnyoc3
johnnyoc3
  • 39 posts
    casio fx 1.0 plus
Posted 04 March 2009 - 06:28 PM
Ive had a casio fx 1.0 plus for a couple of years now (3/4?) and had successfully modded it to use the CAS program. however i haven't used it in a while, about 1 year, and to my surprise one horizontal line of keys not longer works! the line starting with "Ab/c"and ending with "->" does not accept any key presses. all other keys work fine but any key on the "Ab/c" line dont work. This is detrimental to my calculators use since the "(" , ")" , and "->" keys are located there!
i have tried resetting the system components using the commands under "system -> reset" but it has not helped.
years ago i know there was alot of activity with fx program development but i havent really kept up to date with the "scene". I believe there was a program called "touche" (sp) that could detect key presses. so before i go and open up the calc and check for a broken/loose pin is there a way for me to test if its a software/firmware error? i have a link cable so i was thinking if i could download a program to try and see if the key connection is broken or just the software
PS: im a little rusty about which programs were useful tools for transferring to/debuging/hacking the calc. This is the only site i really remember so if someone could point me in the right direction for a tutorial or site of some sort that is slightly up to date with the current state of things would be great.
thanks!
#2 mintsmike
mintsmike
  • 115 posts
    fx-5500L, fx-991ES,fx-9860SD (with GII SD OS), Casio Classpad 330, MS Windows Calc, Ubuntu Calc, a Hammer and my Brain!
Posted 04 March 2009 - 07:16 PM
Hi there, i would suggest that you remove the batteries from the machine for 2 minutes, then press the physical reset button, with no batteries inserted. Then put a new set of batteries into the calculator and again press the reset button. I do not actually own this calc so my knowledge is limited.
Let me know if this helps :rolleyes:
#3 johnnyoc3
johnnyoc3
  • 39 posts
    casio fx 1.0 plus
Posted 05 March 2009 - 06:59 PM
when you say remove the batteries do you mean the main batteries (4 AA), the backup battery (small circular one) or both?
thanks
#4 mintsmike
mintsmike
  • 115 posts
Posted 06 March 2009 - 07:33 AM
I would say both, just for added security.
:rolleyes:
#5 johnnyoc3
johnnyoc3
  • 39 posts
    casio fx 1.0 plus
Posted 07 March 2009 - 02:22 AM
i tried just removing the main batteries and that didnt fix it. now i removed both batteries and will give it a few hours and try again!
also, while the batteries were out i pressed the reset button since that should clear out any extra juice in the capacitors
does anyone know the name of that add-in program that lets you read in key presses from the calculator. i cant remember and i think it would be realyl useful!
#6 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 07 March 2009 - 07:54 AM
I'm afraid it actually needs repair. This is common upon AFX's that have not been in use for a while. The same thing happened to my AFX. I wouldn't be surprised if you opened up your AFX and found corrosion and powder on the PCB traces.
#7 johnnyoc3
johnnyoc3
  • 39 posts
    casio fx 1.0 plus
Posted 07 March 2009 - 08:29 PM
yeah i was afraid of this. neither battery removal methods did anything im going to open it up today at take a look for myself. i can prob figure out the different components of circuit board but is there a picture for reference?
#8 johnnyoc3
johnnyoc3
  • 39 posts
    casio fx 1.0 plus
Posted 10 March 2009 - 07:03 AM
well i opened it up today and i couldn't seem to find anything out of place. :( i'm gunna take a better look tomorrow when i have time but im starting to give up hope on my old baby :(
#9 kucalc
kucalc
  • 1422 posts
    Computer graphics
Posted 15 March 2009 - 08:03 AM
Did you check for any dirt? Try looking under the rubber keypad.
