Hi there,
I'm new to this, i've typed out a couple of games before but i want to type out pacman.
I've got the code by Marcus Lundstroem
In the notes it says:
- Make sure you put four Zero's in List 6 befor playing for the first time. (where do i put them in and do i put them in once i have finished writing the code?)
-I have the fx-9750G, it says not to worry about the colour commands ("orange", "green" which i understand because my calc is B&W) What do i put instead of the colour commands?)
I would really appreciate some help with these Questions.
Thanks alot,
Henry Johnson
Begginer Problems With Pacman For Fx-9750g
HenryJfx-9750G
, Mar 16 2009 03:48 AM
Posted 16 March 2009 - 03:48 AM
Posted 16 March 2009 - 04:21 AM
Hello HenryJfx-9750G and welcome to the UCF!
To type in the zeroes, go to LIST. It's in the MAIN MENU. Then scroll over to List 6 and type the zeroes downward.
For the colors, you don't need to replace them. Just don't type them in.
