I've searched this forum and haven't found my particular problem so I hope this is the right forum and that some kind soul will solve it for me.
I've had my fx9860 Slim, together with FA-124, for several months and have not been able to transfer any files from my PC to the calculator; in particular, eActivities. Connection is OK but the PC window stubbornly remains fixed on FA124, no amount of right/left clicking (single or double) will change it. In the PC window all the icons are grayed out except for the two rightmost icons.
The only folder under FA124 is Default (that I can't change)
I sometimes wish I'd bought the SD version at least file transfer would have been guaranteed.
Is there anybody out there who could suggest a solution to this problem?
