How Do I Use Assembly In Fx-9860g Sdk?
#1 Assembler
Assembler
  • 2 posts
Posted 17 July 2009 - 01:22 AM
Hi,there.
I'm a newbie for 9860g programming,I checked all tuorials which I can found and got nothing.
A way like that (http://www.casiocalc...387&hl=assembly)
is too complicated to me.
I tried to use inline assembly but failed,is anyway to do this simply?
btw:my first goal is just input a number to a variable,but the standard function scanf() can't working...
Edited by Assembler, 17 July 2009 - 01:23 AM.
#2 Andreas B
Andreas B
  • 160 posts
    fx-9860G SD
Posted 17 July 2009 - 10:51 AM
For your question:
Create the assembly file with extension .src and add it to the project.
Example file:
.section P, code
	.export _myfunction
myfunction:
	whatever instructions are needed here
	.end
You can then call the function with myfunction().
For your goal: You could use a function that reads the input as string, and then use something like vsprintf() to interpret it. For an example of a function (in C) for reading a string, see http://casio.pastebin.com/f2ef7343f
Edited by Andreas B, 17 July 2009 - 10:51 AM.
#3 Assembler
Assembler
  • 2 posts
Posted 18 July 2009 - 01:52 AM
Thanks a lot !It's very useful.
#4 Guest_jc_*
Guest_jc_*
  • Guests
Posted 28 March 2011 - 07:37 AM
hello I have a question
is possible to create a password for transfer of programs between calculators or any other transfer
