A Better Equation Writer Then Fa-124 ?
7 replies to this topic
#1 junior
junior
  • 45 posts
    CASIO FX82MS
    CASIO FX82ES
    CASIO FX3600P
    CASIO FX5800P
    CASIO FX9860G-SLIM
    HP 50G
Posted 31 July 2009 - 11:10 AM
i need a program that writes equations and symbols for calculator in PC. because FA-124 does not write equation with symbols. it shows different charecters like ; #E551 , #E556 , #E531 ,....... so it is impossible to see what we write in equation. please help me. i have an examination and i can´t write with this freak method. please show me a better way. many thanks.
#2 Martin
Martin
  • 121 posts
  • Interests:asm on cfx9850
    fx82l
    fx7700GB
    cfx9850G
    TI92
    fx9860G SD
    Rheinmetall KEL IIc
    H. W. Ebmeyer - Tarema
    fx cg20
Posted 31 July 2009 - 11:39 AM
As a simple solution you can write the code in the fx9860 calculator emulator. Then save it to emulated SD card - this exports your file to windows.
Then use FA-124 to transfer it to the calculator.
#3 junior
junior
  • 45 posts
    CASIO FX82MS
    CASIO FX82ES
    CASIO FX3600P
    CASIO FX5800P
    CASIO FX9860G-SLIM
    HP 50G
Posted 31 July 2009 - 11:58 AM
can you help me about emulator and emulated sd card software. which to download. a link please. on the other hand i am using 9860G-SLIM so emulator possible for that, and possible to transfer from that emulator? thanks. (and still waiting for a easier method from you friends.)
Edited by 2072, 06 August 2009 - 10:12 AM.
#4 Martin
Martin
  • 121 posts
    fx82l
    fx7700GB
    cfx9850G
    TI92
    fx9860G SD
    Rheinmetall KEL IIc
    fx cg20
Posted 31 July 2009 - 01:24 PM
Download this: http://www.casio-eur...vities-engl.zip and extract somewhere.
Run NewGraph.exe
Use as normal calculator, write file you want.
Then press <span class=MENU' />, <span class=cos' />, <span class=F1' />, select <program>, press <span class=EXE' />, <span class=F1' />, <span class=F2' />,<span class=2' />
Now use select folder where to save your file.
Type a new file.
Done !
There are more alternative editors, but none (as I know) of them is ultimate.
I wrote simple editor for CASIO basic 10 years ago ( http://www.rkk.cz/~m...NLOAD/CEDIT.ZIP ),
it shows the data exactly as in the calculator, the same font and tokens.
But: it is only for early cfx9850G and older, it is only for raw data, no header support as each calculator has different header.
You can view (edit) files from the calculator in this editor, but you will not see the new commands and you will not be able to send back the file to the calculator, as there is no such communication software.
So I think it's useless for you except for viewing.
Somebody should write converter raw file <-> file in format for the calculator of the type :-)
#5 junior
junior
  • 45 posts
    CASIO FX82MS
    CASIO FX82ES
    CASIO FX3600P
    CASIO FX5800P
    CASIO FX9860G-SLIM
    HP 50G
Posted 31 July 2009 - 04:17 PM
Download this: http://www.casio-eur...vities-engl.zip and extract somewhere............
it gives 404 error and says "nicht gefunden". a link problem? and is this G-slim emulator? and is it possible to use PC keyboard in emulator or only mouse clicking to emulator buttons?
Edited by junior, 01 August 2009 - 09:00 AM.
#6 Martin
Martin
  • 121 posts
    fx82l
    fx7700GB
    cfx9850G
    TI92
    fx9860G SD
    Rheinmetall KEL IIc
    fx cg20
Posted 01 August 2009 - 02:13 PM
There is probably a bug in this forum which kills links.
#7 junior
junior
  • 45 posts
    CASIO FX82MS
    CASIO FX82ES
    CASIO FX3600P
    CASIO FX5800P
    CASIO FX9860G-SLIM
    HP 50G
Posted 02 August 2009 - 11:50 AM
does this emulator not save the last settings, programs vs. does it always resets when we close it. i am asking because it is dangerous to use in this way, your program erasing if you close without saving export to PC, and no settings available in it. when we start, it comes all the settings resetted. ??? any idea, what am i doing wrong. thank you.
#8 Martin
Martin
  • 121 posts
    fx82l
    fx7700GB
    cfx9850G
    TI92
    fx9860G SD
    Rheinmetall KEL IIc
    fx cg20
Posted 03 August 2009 - 08:14 AM
I think it doesn't save anything.
