As topic, may I know is there a different between Int and Intg found under optn->num on a fx-9860g?
Thanks in advance.
Difference Between Int And Intg On A 9860g?
sunnyboy
, Aug 30 2009 03:45 PM
Posted 30 August 2009 - 03:45 PM
Posted 31 August 2009 - 09:30 AM
The manual says that "Intg n" give the nearest lower integer. So for a positive number, using Int or Intg returns the same result, but for a negative one, it is different (Eg : "Int -4.2" gives -4 but "Intg -4.2" gives -5)
Posted 01 September 2009 - 03:54 AM
Thanks!
