void HelloWorldModule::Draw()
// BeginDraw prevents screen updates until a matching EndDraw
BeginDraw();
// Clear the screen
ClearScreen();
// Draw window border
DrawFrame();
// Draw any children objects
DrawChildren();
// Draw "Hey" at relative window position (10,10)
PegColor col;
PegPoint p = {10,10};
DrawTextR(p,"Hey",col,PegTextThing::GetBasicFont());
// Matching EndDraw. If this is the outer layer EndDraw
// then the screen will be updated.
EndDraw();
}This is from HelloWorld.
How can I draw a text, maybe after a buttonclick, later?
I don´t cant edit the window, only when I edit the Draw() sequence.
Edited by NT2005, 28 October 2009 - 09:49 PM.
