Thanks for the warm welcome kucalc!
Yeah,I left batteries out for a day and when I put them back in, I get the same response. I've also pressed the P button only to see the screen clear for the duration of being pressed and back to the picture above. I pressed every button on the keypad to look for a sign but there was none. Can anyone help me?
Hello abdullahkoh and welcome to the UCF!
Have you tried pulling out the batteries for a couple of minutes, then try pressing the P button to reset it? It looks like it's stuck running some BASIC program (infinite loop?). IIRC, pressing the AC power button (or is it EXIT?) will break the program.
