I'm New And Need Help With Fx-991es
#1 james341
james341
  • 3 posts
    fx-991ES
Posted 15 December 2009 - 08:57 AM
good day to you all
i'm so happy i found this forum
i'm learning differential equations course and i purchase casio fx-991ES
and now i don't really know how to use it to my propose
i need to do for now 3 things : integrals , derivative and find fractions in polonium
so for the first thing this is the equation i need to solve :
Posted Image
like you can see i need to do integral to both sides and i see in the fx there's the integral button but i tried and tried and i can't figure how to do it....
for the second thing i need to find fractions to some poloniums like in this 3 examples : (i all ready did it with out the fx but i want to be able to use the fx to find this fractions)
Posted Image
for the last thing i need is to solve derivative like in this example :
Posted Image
tanks a lot for all of you
#2 james341
james341
  • 3 posts
    fx-991ES
Posted 15 December 2009 - 10:34 AM
i just found out now that this calc don't have symbolic and only numeric !!!!!
i can't believe this...
is there something i can do?
and also if someone can help me find other good calc in the same size that can do symbolic
#3 TovAre
TovAre
  • 75 posts
    fx-991CW
    fx-9860GII SD
    fx-9700-GE
Posted 15 December 2009 - 10:53 AM
There are models called classpad and FX. Personally I opted to not have a CAS calculator, although it can be installed as software on my FX-9860G/GII.
Check out Wolframalpha.com, I use it occationally to search for stuff when I can't figure things out (Press show steps):
http://www.wolframal...riv...cos(2y)^2
Regards,
Edited by TovAre, 15 December 2009 - 10:57 AM.
#4 james341
james341
  • 3 posts
    fx-991ES
Posted 21 December 2009 - 05:57 PM
thanks
is the FX-9860GII and the FX-9860G can help me do symbolic integrals , symbolic derivative and find fractions in polonium ?
i need do be able to do the examples in my first post
thanks
#5 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 15 June 2011 - 08:26 AM
good day to you all
Posted Image
Posted Image
Posted Image
