OK, a couple of questions.
1.  If the cas cannot find the antiderivative symbolically, does it say so?
2.  If the default variable is VX, how come you used X and not VX as the variable in the expression to be integrated?  That one really throws me when I try to figure out how to use the 50g!
 3.  How do you integrate sybolically for another variable, say Y?
 4.  Is INTVX a button on the keyboard or the result of a menu option? Or both?
4a.  With all the stuff printed on the keyboard, how do you find a specific command like INTVY? The stuff isn't arranged in alphabetic order.  So what is the logic to the order?  Is there any logic to it?
  5.  Why not keep it simple and have an integration symbol on the keyboard and allow the user to specify the independent variable after entering the expression to be integrated?
 6.  Doesn't it seem that by having a INTVX command rather than a simple INT command that using the calculator becomes unnecessarily complicated?  It just seems to me that the HP designers went out of their way to make things complicated and difficult.  Can you understand that?
  My Hp50g sits in a drawer unused for months because of things like vx and casdir's.  Why the heck should a person have to learn that stuff just to integrate an expression?  I get very angry when I think of all the time I wasted searching thru the manual trying to find answers to questions like these.  With a good product that would not be necessary.  Why should it be necessary!
  7.  Lastly, what is a CASDIR, and why should it even be mentioned?  I don't have to know anything about a CASDIR to do integration with a pencil and paper.  And why is TI going in the same direction, producing nspire/nspire cas calc's that make operation and especially programing very complicated and difficult.  TI, what happened to the simple concept of turning on a calculator, pushing 1,+,1, enter, and seeing two?  Huh?
  None of these user interface problems ever get addressed, so my response is simple, I recommend that people avoid buying the HP50g because "from my experience" it is just to difficult to figure out how to use.  And now that goes for the TI-nspire and TI-nspire cas models also.  Whew!  That is my two cents worth.  Actually, I avoid people and products that life difficult and stressful.  Life is short, why not enjoy it?
   INTVX finds the antiderivative of a function symbolically, with respect to the current default variable VX, stored in CASDIR and typically X.
