Inverse Normal Distribution In Fx-991es Plus
#1 amjad
amjad
  • 2 posts
Posted 13 May 2010 - 09:09 PM
Is this possible to find inverse normal distribution table from this calculator.For example if we are given the probability like0.9131 and we know the value of this is 1.36 from normal distribution function table.
#2 TovAre
TovAre
  • 75 posts
    fx-991CW
    fx-9860GII SD
    fx-9700-GE
Posted 14 May 2010 - 12:01 AM
The fx-991es plus doesn't have that function. You can do P(1.36) and get 0.91 to check that you read the table right.
You might be able to execute this algorithm manually on the calculator.
http://home.online.n...a/normsinv.html
For completeness:
The InvNormCD() function was introduced in the GII models, on the fx-9860GII it's:
Optn -> F5(stat) -> F3(Dist)->F1(Norm)->F3(InvN)
InvNormCD(0.9131) gives 1.360094567
http://en.wikipedia....tors#GII_models
Edited by TovAre, 14 May 2010 - 12:25 AM.
