Hello,
I really need help with how I can add a space inside a formula (or between numbers) without removing any of the current numbers.
When I just press ALPHA+SPACE the space erase the number to the right. Its like the space just "takes the letters place"
Thanks a lot!
![Photo](https://secure.gravatar.com/avatar/d508f977431486319e2bc3555e8a5ba7?s=100&d=https%3A%2F%2Fcommunity.casiocalc.org%2Fdot%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Need Help!
huldra
, May 25 2010 03:43 PM
Posted 25 May 2010 - 03:43 PM
Posted 26 May 2010 - 03:23 PM
Hello,
you need to switch to insert mode - press
Shift' /> and then
DEL' /> .
But it is not a good idea to add spaces into the formula (except in text output). The interpreter will show error on the first space so your program will stop working. Spaces are only for writing text (between "").
![<span class=](/dot/public/style_emoticons/default/SHIFT.jpg)
![<span class=](/dot/public/style_emoticons/default/DEL.jpg)
