Display Problem
Posted 08 August 2010 - 02:20 PM
my e-mail: miroslav.hamsa AT klikni.cz
Guest_Jose_*
Posted 08 August 2010 - 05:39 PM
I have Casio ClassPad 300PLUS. I have had a problem with the touchdisplay (function identification), which I have always solved by resetting and new display calibration. Now the calibration no longer works. The display point identification does not work at all. Please, let me know what to do. Thank you and best regards, Mirek
Call the Casio hot line. In the U.S. the number is 800-435-7732. How old is your calculator? The latest model is the 330 which has been around for quite some time so your calculator is probably not in warrenty and you are probably due for a new one but it doesn't hurt to call and ask.
Guest_Jose_*
Posted 23 August 2010 - 08:58 AM
Hello,
I have the same problem since yesterday evening on my Classpad 300 Plus. I can't calibrate the screen. The display point identification does not work at all and resetting the classpad doesn't solve the problem. I cant use my Classpad at all.
Do you know this problem and what to do ?
Thank you for your answers
Patrick
Guest_JBB_*
Posted 23 August 2010 - 06:10 PM
Quite frankly I would be very disappointed if Casio provided you with any assistance. Everyone else spends their money for a new calculator every few years so why should you be any different? You are being unreasonable and making an effort to get something for free that you don't deserve. My recommendation is that you should obtain an old TI calculator that doesn't work, and try to get TI to fix it or give you a new one for free. You are just the kind of customer that TI should have. Try them, and tell them that JBB sent you. That should work.
It is not my question but your answer that is useless. If it is the only answer that you can give me I could answer it by myself. It is not the first time that the screen freeze on my calculator. It is the second time. The first time I sent it back to CASIO to make it repaired for free. But today I don't want to pay for a new reparing that sound like a calculator default. I am a mechanical engineering teacher and I need it to work.
I have pay a lot for this calculator three years ago and I don't want to invest again in a new calculator of that price.
Patrick
Posted 26 August 2010 - 07:32 PM
You are bunch of F******!
If you do not want to answer the question, then don't!
I have the same issue, and my classpad have never been dropped, not even scratched.
Idiots!!!
Edited by kabel, 26 August 2010 - 07:35 PM.
Posted 09 September 2010 - 05:15 PM
Hi!
So three people here have the same problem as me.
Kabel, Patrick and mirek. And there might be the same problem that the spanish people are discussing in this thread:
http://www.casiocalc...?showtopic=3552
And also two people here
http://www.fixya.com...ought_calss_pad
http://www.fixya.com.../t5924948-casio
It might be that school is beginning now for the fall, and people want to begin to use their Classpad?
I've got a 2,5 years old classpad. It's been used very little, almost nothing at all - I just bring it to some exams where I might have to do some laplace etc.. Anyways - it's in like new condition.
And now, after not having used it for perhaps 4 months, I started it up to do some math, and the touchscreen won't work! I was in the main menu, where I could move the display with the cursor button. I did press the hardware reset button. That brought me to a reset and the screen calibrations menu, touch the crosses, which I can't get passed since the Classpad won't react to any input on the touch screen.
I want to try to do a factory reset, but how could I do this without the touchscreen? Using a PC? Something else?
Edited by mycalculatoryes, 09 September 2010 - 05:23 PM.
Posted 10 September 2010 - 04:25 PM
The real solution is that you dudes need to take your classpads to the nearest casio repairing center, find contact details at http://world.casio.com (Choose country and go to support section, then look for repairing centers). If no repairing centers near you, call your local dealer and ask them what to do.
Someone may want to tell this to the people at fixya too. I don't know why they posted their problems there. Where they looking for any hardware-related solution they can handle themselves? Maybe open their classpads and solder the lcd pins? (don't try this at home!!)
Edited by MicroPro, 10 September 2010 - 04:27 PM.
Posted 10 September 2010 - 06:49 PM
I do as you write and I get to the menu and it asks if I want to "delete all user data", but I don't know how to answer yes? I've tried every button, and nothing makes anything. It just goes into the main standard menu after a while, perhaps 6 seconds.
I don't know of any software way to fix that. I haven't had such a problem before, but if P-button doesn't work, and you can't access reset options in 'System' application there remains only one other way for resetting: Turn your classpad off then press [=] +
EXP' /> + [On/Off] together (hold for a few seconds). This will delete all data from cp's memory AND I'm almost sure it will not cure your classpad so simply don't try it!
Edited by mycalculatoryes, 10 September 2010 - 10:59 PM.
Guest_Jose_*
Posted 11 September 2010 - 01:21 AM
Hi!
No, you did not do as he has written. He offered good advice and said specifically: "The real solution is that you dudes need to take your classpads to the nearest casio repairing center, find contact details at http://world.casio.com (Choose country and go to support section, then look for repairing centers). If no repairing centers near you, call your local dealer and ask them what to do."
Why is it that you don't you do that? Are you stupid or something? No, I think you are just a troll and don't really have a classpad and I think all these posts about the touch screen are all written by one person and it's time for us to ignore you.
Posted 18 September 2010 - 11:05 AM
That was great to hear! Did they do this even if your calculator was out of warranty?
best regards!
Like I said it before, it was the second time that the screen of my classpad had frozen.
I contacted the Casio support and explained my problem.
They answered me what to do.
I sent my classpad to the nearest casio repairing center with the bill, the purchase proof ticket, the first repairing report, and miracle, they sent me back a new classpad.
Great CASIO
Patrick
Posted 11 October 2010 - 04:08 PM
Yes they did.
Perhaps my case was perticular case because when the screen of my first classpad stopped to operate properly, my classpad was on warranty. I sent it to CASIO and they repaired the screen. They sent me back my calculator with repairing report. The second time the screen of the classpad stopped to operate my classpad was out of warranty.
I contacted CASIO support on the WEB and let a message in which I explained the problem. I tell them that I found a little bit more that this problem occurs for the second time for a calculator of that price and that it stayed to me to solutions : the first one they repair my calculator for free and I stay faithful to CASIO or the second one I purchase a new calculator but it will not be a CASIO because of a loose of confidence in the product.
I am a teacher so I think they treat me carefully.
But I do appreciate the fact that they sent me back a new calculator for free. This is the proof that CASIO takes care of its customers
I sent my calculator to the service center and they asked 90 $ to get it repaired because was out of warranty. I told them that i could buy new calculator for that price, and all that they answered was "go ahead and buy one because this one is dead, we are not going to replace it for free, you do not have warranty". I received my classpad in the mail, thrashed it, and went to the nearest store and bought TI-89 titanium that works.
This is going to be my last casio product. Beside the classpad, i own several expensive casio pathfinder watches. No more casio products in my life.
This is the proof that CASIO DOES NOT TAKE CARE of its customers !!!
@ JOSE: You are an idiot!!! Read my post to find why. You are the one that does not have classpad
Edited by kabel, 11 October 2010 - 04:09 PM.
Posted 11 October 2010 - 06:41 PM
After all, nice choice.
I still have my ClassPad 300 and it suits my needs. (Look I personally wont blame others for buying calculators other than ClassPad
Guest_Casio warrior_*
Posted 12 October 2010 - 02:15 AM
