first i learn physics and maths at high school and about my maths curriculum units :
algebra:
permutations , combination and binomial thereom
complex numbers
Determinants
in calculus
limits and continuity
differentiation
application on derivatives
behavior of functions and graphs
integration
and also statics and dynamics in mechanics and solid geometry and a first year statistics
in physics my curriculum units are about waves , hydrostatics , hydrodynamics , heat , electricity and modern physics
this is the last year in the high school
and i wanna join a business school or an economics school after leaving the high school
so what is the calculator that you recommend for me?
afx or fx2.0 + or fx9860 g sd or fx 9860 gii or another calculator?
i like the feature that is called tutor but i know that afc 1 and 2 only have this feature so if i gonna buy the fx98** series can i download the tutor and CAS features?
also can i close the backlit in the fx 9860 gii because in my country Egypt if the teacher sees calculator that has a backlit or something like that he may not allow me to use it because he may think that this device is an organizer or a pda or a portable device so can i close the backlit?
i own now a beginner calculator called fx 500 es and wanna upgrade it.
also i think i will buy a standard scientific calculator for my sister so the best one for her till the university is fx 115 es or something else?
Cheers
waiting for your replies
Edited by RupertHentzau, 28 November 2010 - 07:39 AM.
