factorials (X!) alg fx 2.0plus HOW!
#1 gagarin
gagarin
  • 2 posts
Posted 23 May 2003 - 06:11 PM
anyone know how to work factorials in FX 2.0 +?
can't find an x! [I][I] anywhere!!
ta
gagarin
#2 Rigel
Rigel
  • 12 posts
Posted 23 May 2003 - 06:21 PM
First type in the number you want to get the factorial of, then press, respectively, OPTN , F6 , F1, EXE. You will get the "!" sign, then press EXE. This will output the factorial.
#3 gagarin
gagarin
  • 2 posts
Posted 23 May 2003 - 11:11 PM
hey!
thanks Rigel!
scratched my head for some time on that one
ta
gagarin
#4 XYZ
XYZ
  • 46 posts
  • Interests:Lying on the beach on a hot sunny day
    Casio AFX2.0+, CFX9850, HP49G, fx-7700GB, TI-85, TI-92, HP20S scientific....
Posted 24 May 2003 - 06:51 AM
Also if you want to do any big factorials (afx2 is rather lax there, can't evaluate 100!/99! etc...) you might try using the product command in cas -
product(x,x,1,upper limit(ie the number whose factorial you want))
Try it and see
#5 X-thunder28
X-thunder28
  • 192 posts
    2 Graph100 (rom 1.02 and rom 1.03 (+) )
Posted 30 May 2003 - 01:24 PM
in CAS you can directly input
100!
for exemple !
