What is the problem? Can this calulator really use e? ??xcel files from computer or no
Posted 27 January 2011 - 10:18 PM
Posted 28 January 2011 - 01:26 AM
To export to CSV in Excel:-..I have tried several attempts to convert the excel file to CSV..
Hello, I tried playing with CSV related feature a little and was not so impressed:-
-CSV file (without text data) exported from Excel works well, I can assign a formula that refer to those imported value. All calculation works. (In fact, CSV is for "Comma Separated Value"-- a text file containing numeric value in text, a data item was separated from each other using commas, you don't need Excel to create it, just notepad is all you need: type in numeric value and separate the data columns with comma, rows with new line and save the text file you created in CSV extension)
-When I export a spreadsheet from the PRIZM to a CSV file, all text data was truncated to null data (in CSV it will be adjacent commas).
-When I import a CSV file containing text data, an error occurs and importing fails.
-When I export a spreadsheet with formula(s) in cell(s), only calculated value was exported as numeric data. (of course, this applies to all CSV exporting, no matter of what program you use to export--including Excel)
So, you can see that only pure numeric value is usable in CSV file with the PRIZM. That's why I wasn't so impressed. BTW, It's much better than nothing-- you don't need to re-key all numeric value and maybe we don't need text in the PRIZM much (really?). This feature is very useful for statistic calculation when you collect data not using EA-200.
