Casio Classpad 300 Os Update Problem
#1 ze_rafael
ze_rafael
    Casio ClassPad 300
Posted 24 February 2011 - 12:45 AM
Hi
I have bought recently a casio classpad 300. It comes with os version 1.00.0000
I tried to update to version 2.20.300 but i cant.
ClassPad 300 OS Ver.02.20.3000 Update says that the instalation was interrupted.
"The wizard was interrupted before ClassPad 300 OS Ver.02.20.3000 Update could be completely installed. Your system has not been modified. To complete installation at another time, please run setup again."
Do you now how to solve this?
Windows 7 64 bits
Edited by ze_rafael, 24 February 2011 - 01:28 AM.
#2 Guest_Fingily_*
Guest_Fingily_*
  • Guests
Posted 24 February 2011 - 06:20 AM
Visit http://edu.casio.com/dl/ and enter the download site. Check 'Software for Ver.3.05 (Windows7 64bit)' under 'â– ClassPad Manager series for Windows7 64bit' and install it. This installs the necessary drivers on your system and slv ur prblm.
#3 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 24 February 2011 - 07:14 PM
Windows 7 64 bits
This is not supported! You need OS 3.05 for this.
But for OS 3.05 you need OS 3.00 first (which does not work under 64 bit, too!).
Have a closer look at this forum, the OS 3.00 link should be somewhere.
#4 Guest_Guest_*
Guest_Guest_*
  • Guests
Posted 24 February 2011 - 07:16 PM
Here, it is: http://www.casiocalc...=...ost&p=49720
#5 Guest_Guest_ze_rafael_*_*
  • Guests
Posted 24 February 2011 - 07:46 PM
I cant donwload the 64bit. I dont have the registation code...
Can someone donwload it for me please?
