Hello,
I would like to be able to create an executable dichotomous key (basically they are a type of flow chart with two options for each question/characteristic) for my calculator. I don't really understand how to do this. I can write the code for the first question, but then I don't know what to do. If I could see even a simple example of what to type in I'm sure I could extend it to larger keys.
This page contains a very basic example of a key, for identification of a duck, hen, lizard and snake. If you could show me the code I would greatly appreciate it as an example. http://www.lucidcent...dichotomous.gif
Of course, what I really want to do is make something more complex, like this one http://www.bmb.leeds...am_negative.gif but if it is possible to create a smaller example that I could substitute text phrases and extend (without requiring other commands, because then I wouldn't understand how to do that too) to produce larger ones that would be great.
Please help if you can; it is appreciated, and thank you for your time.
Edited by GrandLocomon, 12 April 2011 - 03:14 AM.
