I need to solve it using a GDC, but I haven't got a clue how to do that.
My calculator is CASIO FX-9750GII (I think the menu is the same as 9860)
Please give me instructions on how to input that data into the GDC. thanks
How Do I Solve The Stats Question Using Casio Fx-9750gii? Help!
the_13th
, Apr 21 2011 11:01 PM
Posted 21 April 2011 - 11:01 PM
#2 Guest_guest_*
Posted 08 May 2011 - 11:20 AM
#3 Guest_Guest_*
Posted 08 May 2011 - 11:29 AM
i don't own a casio calculator, but there should be an inverse standard normal distribution function. enter the probability and you will get z, or you can look it up in your book. that will give you the number of standard deviations you are away from the mean. so so multiply z and standard deviation, then add to the height for that probability. now you you have the mean, you can do use the the normal distribution function by entering the mean, standard deviation, and the height to find the probability.
