Fa-124 Not Linking To Calculator
#1 Matthew
Matthew
    FX 9750-GII
Posted 25 May 2011 - 10:20 AM
I have a FX-9750GII and am running FA-124 Ver. 2.0 on Windows XP
I've used this program and calc fine in the past, but for some unknown reason FA-124 does not recognise the calculator is plugged in.
I've set the Coms link to USB, set the right model type and pressed Recieve on the calc.
Any ideas?
If not, if anyone knows of an alternative program - I just need to transfer notes to calc.
Thanks alot,
Matt
Edited by Matthew, 25 May 2011 - 10:22 AM.
#2 flyingfisch
flyingfisch
  • Deputy
  • 1891 posts
    fx-9860GII
    fx-CG10 PRIZM
Posted 25 May 2011 - 07:49 PM
Simon Lothar's file converter has an option for that. you may want to try reinstalling FA-124 and checking your link cable for damage.
BTW: if anyone happens to anyone else, could you tell me what causes it? i start up FA-124 and it has an error box that says "application error". it works fine, im just wondering whats causing it. Thanks in advance.
