Is there a way to create a formula where i can input variables, and it will calculate a result?
for example, i want to create an equation in the form;
y=x^3+2x=2, and then input an x value so it gives me the corresponding y value.
do i need to create a program? or can i do this from the RUN-MAT menu?
any help would be much appreciated
thanks
