Using % To Mean Percentage
RadSurfer
, Jul 20 2011 05:24 AM
Posted 20 July 2011 - 05:24 AM
Most calculators actually use % to mean exactly that! Per-cen-tage!
On this silly CG10, % is some silly list-function thing.
Casio FX115es has proper %
Casio 9860*, just like silly CG10 does not
TI89T actually has %. You can guess what HP50G has.
Such a small insignificant thing, but it is a HANDY thing to have! and it is MISSED when
not present!
So what to do? Define a function Per(), etc? Gasp.
Any comments/rebuttals?
--RadSurfer--
not present!
--RadSurfer--
Guest_Guest_*
Posted 20 July 2011 - 08:50 AM
E.g. 7000x5% is the same as 7000x0.05
Posted 20 July 2011 - 11:45 AM
not present!
--RadSurfer--
The percentage sign is very strange when used as an operator, how does it work on the TI ?
Does the 9860 (GII) have a percentage function? (I'll have to check it out when I get home, I've never used it.)
For instance: 100 + 5% = 105, which almost makes sense, but what would you do with 50 + 50 + 5%, if the + sign has lower precedence it would be the same answer 105 otherwise it might be 102.5 ?
As the other poster said, I think maybe getting used to writing: 100 * 1.05, then there would be no confusion about 50 + 50 * 1.05 it would be 102,5 and (50+50)*1.05 is 105.
Posted 22 July 2011 - 01:23 PM
I've never used it either, in fact, I don't believe I have seen it either. Can you give us a keystroke?
