I did a search and found your forum from a related link. (http://www.casiocalc...?showtopic=5545) I'm having the same problem this guy is having. When I try to start Conversion, it won't start and gives me the following: "This enables the Conversion function". Upon looking under System-> Version, I can still see I have Conversion 1.01 installed. I've done a main memory reset and setup data reset but can't seem to get this to work. I've looked on Casio's site for a fix and can't find anything. Is this a weird glitch? Or am I missing something?
Any ideas? Thanks!
ZF
![Photo](https://secure.gravatar.com/avatar/c69b958ecd479bfc8b9884a36b7adb0e?s=100&d=https%3A%2F%2Fcommunity.casiocalc.org%2Fdot%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Prizm Conversion Feature Not Working
zombiefan
, Aug 14 2011 01:58 PM
Posted 14 August 2011 - 01:58 PM
Posted 15 August 2011 - 07:57 AM
This is normal behaviour. Once you've installed Conversion, go to Run-Matrix, press OPTN and press F6 to find an option named CONV (at F2, if I recall correctly).
Posted 15 August 2011 - 11:34 AM
Ah! Thank you so much! I was assuming it would present a screen allowing once access to quick tools for finding standard-to-metric, etc , similar to that under the Financial icon (amortization, etc). This definitely ends some confusion.
Cheers!
Cheers!
