Flash100
Posted 16 July 2003 - 05:39 AM
I download Flash100 from this site :
http://www.2072produ...nloaD/flash100/
Please help me step by step !, 2072
Thanks
Posted 16 July 2003 - 02:17 PM
Posted 17 July 2003 - 12:31 PM
But I can not use it Because I don't know Flash100 for upload *.exe files.
The other program ( FA-123, Casio Add-in installer, ...) can not upload *.exe files to AFX 2.0+.
(FA-123 for *.cat , Casio Add-in installer for *.cfx)
( for *.exe )
Please help me ! Thanks
Posted 17 July 2003 - 12:43 PM
But I can not upload *.exe file with Flash100 !
Where I insert the *.exe files to Flash100 and ... !
Posted 17 July 2003 - 02:54 PM
Posted 17 July 2003 - 03:40 PM
Posted 17 July 2003 - 06:37 PM
1) Choose the drive where you want to load the *.exe file
2) Choose the options of that drive, then "choose a file".
3) Put on "file name" *.exe, and then go to the folder where you have the file that you want load on the calculator.
4) Send the file to the calculator
I hope that this reply help you.
Posted 18 July 2003 - 04:16 AM
Posted 18 July 2003 - 07:12 AM
http://earth.prohosting.com/afx2plus/
or
http://earth.prohost...~afx2plus/F.jpg
Please help me !
Posted 18 July 2003 - 08:49 AM
Why ?
Posted 18 July 2003 - 07:16 PM
I start writing the flash memory of the calculator two weeks ago, using add-in installer (casio oficial software), and my calculator fall on error one time (i had to push the P button). Then i was using the calculator, i upload my basic programs and about 5 days later the programs have been deleted (like someone push the P button).
Its strange
Posted 19 July 2003 - 11:45 AM
But also my calculator does not work .
My calculator hanged.
Why ? Is it a hardware problem ?
Posted 19 July 2003 - 12:46 PM
Posted 19 July 2003 - 06:17 PM
Just do what CrimsonCasio said to reset your calc, it has to work...
Posted 20 July 2003 - 02:59 AM
Posted 21 July 2003 - 04:41 AM
Please help me!
Posted 21 July 2003 - 04:45 AM
Should I turn into *.exe to *.lec ?dont you have to turn them into .lec files or something?
Posted 21 July 2003 - 11:49 AM
Now that you've a .lec file choose a drive and use the file you've just created...
Posted 21 July 2003 - 12:29 PM
Should I choose a System File and How to find it ? (*.MemS,*.csf)no, in the white area on the right of flash100 click right mouse button and click on the first entry, and choose exe files to add, then click on the first buton, "Cr?er un lecteur" and choose a filename.
Posted 21 July 2003 - 03:33 PM
Posted 21 July 2003 - 04:46 PM
But the program does not upload !
Should I choose a System File to open the program from desktop of AFX 2.0+ ?
Posted 21 July 2003 - 07:22 PM
i have the same problem, the programs are uploaded well, but in the "desktop" there's no icon of the files uploaded.
Posted 22 July 2003 - 12:25 AM
We need an "file explorer", to read the flash memory. I do this recommendation of crimsoncasio and works very well:
"use the Casio Add-In Installer to upload a file explorer like "linl"(you can download from the crimsoncasio website), then put all your other programs on the other drives with Flash100 (just not L because thats where the explorer will be) then you can run them using the explorer. "
I think that this topic end with this reply, finally I learnt to use flash100.
Posted 22 July 2003 - 02:59 AM
Is it "http://crimsoncasio.tripod.com/" ?
I can not open this site.
Can I download it from another site ?
#25
Posted 22 July 2003 - 06:27 AM
#26
Posted 22 July 2003 - 06:35 AM
Flash100>>>
firstly you must select your serial port and cable. "Auto" doesn't work with WindowxXP
Secondly, you must create a virtual Lector. This virtual lector is going to contain exe files you want to upload.
You make a left click on 'drive creation' and select 'add-files'.
You build drive and associate the lector with a free drive.
Finally Your calculator: mode 'receive' and you press F5 you begin the communication.
#27
Posted 22 July 2003 - 02:18 PM
Please get me the address of "file-explorer" for download ...I suppose you have uploaded a file-explorer with Add-installer for example.
Flash100>>>
#28
Posted 22 July 2003 - 03:12 PM
But, you can create your icones with flash100: first select the system drive, give it a filename on your computer then on your calc press F2 and on Flash100 press F6. This will download your system area from your calc to your computer.
Then on the system drive click "option" and click view ; now you should have a complex window that displays your main menu, explore this area, using this you can create icones.
I hope it'll work!
#29
Posted 22 July 2003 - 03:23 PM
#30
Posted 22 July 2003 - 04:23 PM
#31
Posted 22 July 2003 - 06:48 PM
http://www.crimsoncasio.co.nr
Only you need to install linl with the add-in installer(on L:), and the *.exe files to the other drives (M~Q). To open one exe file on the calc., first open linl , this program search the files on the flash memory and visualize them to the user. The only disadvantage is that no icon from the file is on the "desktop".
#32
Posted 23 July 2003 - 05:30 AM
Oh Yes , Only by Flash100. OK !If you want a simple and effective file explorer just download TOUCHE (on my website) there is a .cfx that you can use with add-in installer so you have an Icone in the main menu.
I hope it'll work!
Thank You VERY MUCH
#33 Guest_Guest_MathManiac_*_*
Posted 01 October 2009 - 11:37 PM
Do you have any version of flash100 that may run on a pen, on a computer where i do not have administrator priviledges? (it sucks, but it is the only computer i have access right now with a COM port)
#34
Posted 02 October 2009 - 12:28 AM
Yup.. just found the answer to my question:Hi ppl (good to be back).
Version 1.31 runs from a pen without any problem. It is not in the downloads list from ucn, but i still can get it on the Flash100 site.
http://flash100.free.fr/xoops/modules/wfdo...wcat.php?list=F
