Need Help With Graphs!
Posted 10 October 2011 - 05:52 PM
I have a good ole' Casio CFX-9850G PLUS, that has allways worked fine for me until recently. The problem is that it can't seem to plot sin, cos and tan graphs properly anymore. I have allways been able to do this before, but now when I try to make it draw sin x, it just draws a diagonal line. It also draws the exact same line with tan x, and it dosen't draw anything at all with cos x.
The first time it occured, I reset the memory and it worked again. However it happened again and this time it didn't work with resetting the memory.
Is there any way to fix this or do I have to buy a new calculator?
Thanks in advance!!
Posted 10 October 2011 - 11:13 PM
Hello!
Thanks in advance!!
hi. i think your calculator is not in the Rad Mode.
for change this setting hit
and inside one of them hit
come down to see Angle and change it to Rad (you can change this setting by hit
if these solution worked for you; reply to this post
because i have not CFX-9850G PLUS.
Posted 11 October 2011 - 07:31 AM
for change this setting hitMENU' /> and open RUN or GRAPH by hit
EXE' /> key
and inside one of them hitShift' />
MENU' /> to open SET UP
F1' /> or
F2' /> or
F3' /> ).
works now thanks!!
