Miscelaneous questions
Posted 22 July 2003 - 11:50 PM
To start, I have one:
If i push the P button continuously (like 1 time on a week), can i harm the calculator?
Posted 23 July 2003 - 09:08 AM
I don't think it could harm memory or sth, but it's sure you can break up P button
Another question - Have you ever had the problem that while using software your calc has been shut and then after turning it on main memories were cleared?
Posted 23 July 2003 - 02:50 PM
Posted 24 July 2003 - 12:57 AM
When i finish the calc-PC interface, i upload to the calc. a lot of programs and games on basic. One time i play a car game called "Race 2", and then everytime that i make a graphic or play a game on Graphic mode, the image of the city(Race 2) appear. I cant quit that image from my calculator until i reset the calc.
I never knew the reason of this. <_<
Posted 24 July 2003 - 06:59 AM
Posted 24 July 2003 - 08:04 AM
Posted 24 July 2003 - 01:26 PM
Posted 24 July 2003 - 06:35 PM
Crimson, i will send you my basic programs, perhaps probably some of them will like you, for add to your website ( i thing that the program called C its so good).
Posted 24 July 2003 - 06:37 PM
Posted 25 July 2003 - 05:29 AM
Pressing the shift button, when the cursor behold the "S" form, press the left and right arrows of the replay button to change the contrast.
Posted 25 July 2003 - 09:28 AM
Posted 25 July 2003 - 10:57 AM
is that the calculator or me?
Posted 25 July 2003 - 08:36 PM
Posted 26 July 2003 - 03:24 AM
what did you buy ? only the calculator, or wich cables come with it, (calc to calc, etc..) or the digital pencil.
Did you buy the calc-pc interface? which were the final price you pay?
One comment, i see it on casio website:
"The part in the software which operates equivalent to the actual ClassPad 300 operations expires after 180 days. However, the communications part for communication between the ClassPad 300 and the PC can be used continuously."
Bad, too bad...
Posted 26 July 2003 - 12:29 PM
Posted 26 July 2003 - 11:12 PM
Posted 26 July 2003 - 11:29 PM
Posted 27 July 2003 - 01:02 AM
Posted 27 July 2003 - 01:04 AM
Posted 27 July 2003 - 01:33 AM
Does this stop flickering on CFX? Not that it's much use anyway... but you could make something...the reason is that race 2 and other games set a picture as the background, it keeps it from flickering and speeds things up a bit. to get rid of it go into setup and change background to None, on the CFX you have to be in graph mode to do this.
and whats up with casiokingdom
Please reply: where is ANY minesweeper game that opens up all the surrounding blank squares when you click one, or ANYTHING similar. You know what I'm talking about!
Posted 27 July 2003 - 02:18 AM
In the AFX 2.0 one day i was uploading programs with flash 100 and all was OK. I disconnect the calc from the interface to see the programs uploaded.
Moments later I connect again the calc to data transfer but an error appear. I restart the PC and the error still appear on the calc. when i send or receive data. I try (in the hidden menu pressing F6+a b/c+AC), pressing 5(TRS), then 1(COM check), and 0(self) and this appear:
<<<< COM NG >>>>
What is that? com no good? Is my calculator serial port damaged
Posted 27 July 2003 - 01:25 PM
If you have any question about it, just send it to me??..
Posted 27 July 2003 - 04:34 PM
Thanks for the recommendation .
Posted 27 July 2003 - 04:48 PM
The manual of this calculator its only in english? I really have a lot of problems to understand math terms.
#25
Posted 27 July 2003 - 06:10 PM
#26
Posted 27 July 2003 - 10:11 PM
whats this about a file being corrupt!?Right, i will download it later because i want to learn the graphics mode of the calculator(and the file of the crimson website was corrupt ??), i have never make an program in G.M. But the crimson website is being updated.
hmm, strange, there is something wrong with it, I reuploaded it and it should be fine now, plz try it again.
#27
Posted 27 July 2003 - 11:37 PM
#28
Posted 27 July 2003 - 11:40 PM
#29
Posted 28 July 2003 - 06:59 PM
If anyone have a program like this, tell me, to download it and see it. I think that i'm not a good programator (I use about 30 IF sentences in this program)
#30
Posted 28 July 2003 - 07:32 PM
1->T Do Do GetKey->G LpWhile G<>0 G->List 1[T] LpWhile G<>31
am i missing something here, I dont understand why you would need 30 Ifs...
#31
Posted 28 July 2003 - 07:40 PM
#32
Posted 28 July 2003 - 07:44 PM
#33
Posted 28 July 2003 - 07:48 PM
#34
Posted 28 July 2003 - 08:16 PM
and yeah, the classpad has string ops so this is very easy.
#35
Posted 29 July 2003 - 01:12 AM
I will tell to an uncle that i want to buy the classpad, he usually go to L.A. Does anyone know a shop that sell the calculator to a acceptable price?
#36
Posted 29 July 2003 - 02:47 AM
#37
Posted 29 July 2003 - 02:55 AM
#38
Posted 31 July 2003 - 12:16 AM
I am using the AFX 2.0 plus. You can have a tangent line equation in CAS mode. But i have just found that you can also do this in graph mode.
First enter graph mode. Press Ctrl-F2 (setup), then set Derivative On.
After that, store a function and draw the graph. Next, Press F3(SKTCH), Tangnt, and then enter x-value. You should see the tangent line equation to the graph at this point.
Example: y=x^2-x-2. The equation of the tangent line at the point (-1,0) lies on the parabola is -3x-3.
Try this.
#39
Posted 31 July 2003 - 05:19 AM
You must connect 2 AFX together in order to make the test menu work.
What did the transfer program on the PC / calc say what the error is about?
What program do you use.
I use the P button ~100 times a day (errornous asm programs :-) ) and it doesn't harm the calc :-)
#40
Posted 31 July 2003 - 08:35 AM
You're glad that I'm no moderator / admin or your post would already have been deleted.
ADMIN EDIT: Post deleted, and actions are going to be taken, everything under control. ROGER
