Casio Prizm Won't Turn On And Batteries Get Hot
Posted 13 January 2012 - 04:44 PM
Went to the libary yesterday to study and my Prizm would not start so I went and bought new batteries and noting but the new batteries got super hot.
I bought it from USA (Ebay) and I live in Sweden so I don't know if I can send it in to Casio here in Sweden or if I need to send it to the US?
Is there anything I can do or is it try to talk to Casio or throw it in the trash?
Posted 13 January 2012 - 06:15 PM
I am not trying to insult you by asking this, just checking: Are your batteries in the right way?
If thats not the problem, you might want to try reinstalling the OS.
Posted 13 January 2012 - 06:25 PM
Dont throw it away
I am not trying to insult you by asking this, just checking: Are your batteries in the right way?![]()
Yes my batteries is place right
How do I reinstall the os?
Nothing happens if I plug it in to my computer.
Posted 13 January 2012 - 06:51 PM
I am assuming that you use windows. Double click on the installer file that you have downloaded. Follow the directions. This should reinstall your OS.
Posted 13 January 2012 - 07:22 PM
Go to this page and "OS update to version 1.03". Click "accept", and click the checkbox that says "OS Update V.1.03" under "FX-CG series". Click "next" and then download the file.
But sense the calc wont start I can't reinstall the OS. It wants me to go in to settings and select OS update on the calc before I flash. I tried anyway but it just says that the update failed.
Posted 13 January 2012 - 07:38 PM
The primary emergency OS update can be triggered by simultaneously holding down
Release every button. The calc should show a blank display now. Finally press
EDIT: Try this too:
Press
![[AC/on]](/dot/public/style_emoticons/default/AC-ON.jpg)
Release the RESTART button and wait until the screen becomes white
Now release the remaining three keys
Press the
and this:
Press
When the pop-up window appears, press the
And confirm deleting all data by pressing the
Posted 13 January 2012 - 07:44 PM
Try doing this to get into OS Update mode:
The primary emergency OS update can be triggered by simultaneously holding downF2' /> ,
4' /> and [AC-ON] while pressing the RESTART-button.
Release every button. The calc should show a blank display now. Finally press9' /> and
×' /> consecutively.
EDIT: Try this too:
PressOPTN' /> +
EXP' /> +
and the RESTART button
Press theMENU' /> key to show all available options
and this:
PressOPTN' /> +
EXP' /> +
to turn on your calculator
When the pop-up window appears, press theF1' /> key
And confirm deleting all data by pressing the9' /> key
None of the combos work, the calc is still dead
Posted 13 January 2012 - 07:55 PM
Send it to Casio, with warranty, you should have right to get a new one...
The first Prizm dead... (that i saw)
Posted 13 January 2012 - 08:02 PM
Posted 13 January 2012 - 08:06 PM
And welcome to the forums!
You may want to introduce yourself: http://www.casiocalc...?showtopic=5677
Posted 13 January 2012 - 08:08 PM
Posted 13 January 2012 - 08:16 PM
Also, casio will probably refund the calc since it was a hardware defect, regardless of whether you tampered with it or not.
Just ask them, it cant hurt!
Posted 13 January 2012 - 08:21 PM
I don't know if buying an nspire is a good idea.
Will call them on monday
Sense theres no CAS for the Prizm I was thinking about the Nspire. I bought the calc New from Ebay will the warrenty still cover it?
Edited by lirkaren, 13 January 2012 - 08:26 PM.
Posted 13 January 2012 - 08:24 PM
Posted 14 January 2012 - 02:29 PM
I don't need the cas version sense I will probably never use those functions after the course I take now and theres just a few math problems in my book where they recommend a cas calc.
So if I don't get a new Prizm form Casio I will have to choose between the fx-CG 20 and the Texas Nspire CX non cas.
Can you give me pros and cons for both calcs?
Sense this is a Casio forum I will ask at a Ti forum aswell
But from what I have read.
Casio:
Pros: Easy to use and understand, bigger screen? Better support from the community?
Cons: If I don't get a new one thats a con in my eyes.
Texas:
Pros: Better math capabilities? (My Prizm has done everything I needed it to do and more exept for the cas ^^)
Cons: Harder to use (Love Casios menu system), smaller screen? Non replaceble batteries?
Edited by lirkaren, 14 January 2012 - 02:34 PM.
Posted 16 January 2012 - 06:52 AM
Also, the Nspire series doesn't support unsigned native code at all, and all attempts to enable it have been blocked.Comparison of both calcs:
http://www.techpower...vs-casio-prizm/
Posted 16 January 2012 - 08:36 AM
I need to order a new calc so I can get it this week couse it takes to long to solve some things for hand when it takes 4 seconds to do it on the calc.
Posted 16 January 2012 - 10:52 AM
Edited by lirkaren, 16 January 2012 - 11:08 AM.
Posted 16 January 2012 - 02:53 PM
Posted 16 January 2012 - 05:24 PM
Great!
Yeah but I talked to the service place and they said that it may not fix it they have to take a look at it first
Posted 17 January 2012 - 09:28 PM
Posted 18 January 2012 - 09:06 AM
Huh. Well, try sending it in. You said it wouldnt be a big deal if they couldnt fix it, right?
I have thought about if it's worth the money to buy a cas calc and sense im not going to use the cas function after this course it would be a waste of money to buy a new calc. So if they can't fix it i will probably buy a new prizm witch is kind of a biggi sense it feels like waste of money.
#25
Posted 18 January 2012 - 02:20 PM
#26
Posted 18 January 2012 - 02:41 PM
There isn't.I think there is a 3rd party CAS addin for PRIZM
#27
Posted 18 January 2012 - 02:55 PM
#28
Posted 07 February 2012 - 10:32 AM
I oderd a new Prizm from the US for $45 but got it for free becouse my aunt wanted to give me it as a gift
#29
Posted 07 February 2012 - 02:27 PM
