How To Create Buttons Within Programs?
#1 Alfie Stoppani
Alfie Stoppani
  • 13 posts
    Fx-9750Gii (with OS 2.00.0200 updated and installed)
Posted 02 March 2012 - 05:41 PM
I would like to write a program using buttons. So, for example, when the program is first launched, a screen appears with a number of options. Let's say if <span class=F1' /> the program is told to Goto 1, and the code under Lbl 1 would come on screen, and if the program was executed again and <span class=F2' /> was pressed, then Goto 2 would be shown for example.
I assume this uses loops but I'm quite new to programming and don't know how to use loops to make buttons.
Hope you can help. Thanks.
Alf <:3D~
#2 flyingfisch
flyingfisch
  • Deputy
  • 1891 posts
    fx-9860GII
    fx-CG10 PRIZM
Posted 02 March 2012 - 05:49 PM
Ok.
Here is a simple way to do it:
While not Getkey  //loop while no button is pressed
Getkey -> G
WhileEnd
G=79 => Goto 1  //If F1 is pressed, goto 1  (79 is the code for F1)
G=29 => Goto 2
Lbl 1
Stuff to do if f1 is pressed
Lbl 2
stuff to do if f2 is pressed
Hope that helps ;)
#3 Alfie Stoppani
Alfie Stoppani
  • 13 posts
Posted 03 March 2012 - 06:20 PM
I can't get your code to work, it just shows the things in labels 1 & 2 simultaneously, and seems to bypass the getkey looping bit.
I tried this code: [codebox]Goto 3
Lbl 1
"I Just Pressed F1"
Goto 0
Lbl 2
"I Just Pressed F2"
Goto 0
Lbl 3
While Not Getkey
Getkey -> G
WhileEnd
If G=79
Then Goto 1
If End
If G=69
Then Goto 2
If End
Lbl 0[/codebox]
And it doesn't work, just says 'Done'. What am I doing wrong with this modification to the previous code?
Alf.
#4 flyingfisch
flyingfisch
  • Deputy
  • 1891 posts
    fx-9860GII
    fx-CG10 PRIZM
Posted 26 March 2012 - 06:39 PM
Oh wait, try this:
While Getkey=0 or Getkey =21  //loop while no button is pressed
Getkey -> G
WhileEnd
G=29 => Goto 2
Lbl 1
Lbl 2
#5 somebody1234
somebody1234
  • 51 posts
    Casio fxcg10
    Casio fx-9860GII
    Casio Classpad 400
Posted 08 February 2014 - 01:49 AM
Maybe you can use Do LpWhile to loop unless f1 or f2 is pressed:
Do
Getkey->G
LpWhile G≠79 And G≠29
G=79 => Goto 1
G=29 => Goto 2
Lbl 1
Lbl 2
#6 flyingfisch
flyingfisch
  • Deputy
  • 1891 posts
    fx-9860GII
    fx-CG10 PRIZM
Posted 09 February 2014 - 03:36 AM
That works.
Also, Lbl's and goto's are not the best coding practices. Maybe this code would be faster (slightly)?
Do
Getkey->G
If G=79
Then
'Stuff to do if f1 is pressed
If G=29
Then
'stuff to do if f2 is pressed
