I am Trying to calculate trigonometric functions with my calculator.
For example:
tan 30 = 0.5773502692
Instead I get this result:
http://img154.imagev...io_122_66lo.JPG
How do I configure the calculator to get the result to be like above?
![Photo](https://secure.gravatar.com/avatar/65931d7f80a14c52b67fc81bc427f5f5?s=100&d=https%3A%2F%2Fcommunity.casiocalc.org%2Fdot%2Fpublic%2Fstyle_images%2Fmaster%2Fprofile%2Fdefault_large.png)
Need Help Configuring Fx-9860gii
DrBanner
, Apr 28 2012 06:47 PM
Posted 28 April 2012 - 06:47 PM
Posted 28 April 2012 - 07:37 PM
Use the f <-> D key
![;)](/dot/public/style_emoticons/default/wink2.gif)
Posted 28 April 2012 - 09:42 PM
You could also do (From the Run-Matrix screen):
2nd->MENU (Setup), F2. This will take your calculator out of CAS mode, so that it will evaluate all expressions fully.
Posted 29 April 2012 - 01:09 PM
Use the f <-> D key
Thank you.
![:)](/dot/public/style_emoticons/default/smile.png)
Posted 30 April 2012 - 01:44 PM
Ti [2nd] == Casio
![<span class=](/dot/public/style_emoticons/default/SHIFT.jpg)
Posted 01 May 2012 - 10:17 PM
Ti [2nd] == Casio
:P
