Casio-basic To Sdk Development
Posted 08 May 2012 - 07:18 AM
Can anyone help me in developing my casio-basic file to c/SDK?
It has simple codings and easy to do.
Am not familiar with the SDK so please help me.
Thanks in advance.
Posted 08 May 2012 - 01:55 PM
Posted 09 May 2012 - 02:15 AM
Hi everyone.
Thanks in advance.
Do you have the sdk installed already? If not check out the Prizm SDK Setup Guide. Of course you haven't said what modle you're using either...
Posted 09 May 2012 - 03:01 AM
http://oron.com/ckivskck4tve
Am using FX-9860GII.
I thought of having it in the SDK because it is faster and more protected.
Thanks.
Posted 09 May 2012 - 09:31 PM
The link for my Casio-Basic file.Its in G1M format.
Thanks.
Ok, you'll want the officoial casio sdk. You then need to learn C, and then rewrite the code so that it can be compiled. Can you give a brief synopsis of what your program does? (I generally don't download stuff from sites like where you linked [too many ads]; you should try setting up a google site; they have free file hosting)
Posted 09 May 2012 - 10:02 PM
He can also upload to our file sharing serviceOk, you'll want the officoial casio sdk. You then need to learn C, and then rewrite the code so that it can be compiled. Can you give a brief synopsis of what your program does? (I generally don't download stuff from sites like where you linked [too many ads]; you should try setting up a google site; they have free file hosting)
Posted 09 May 2012 - 10:11 PM
That needs to be updated drastically. 2072 said he'd fix it over the summer (june or sometime)
Posted 10 May 2012 - 01:33 AM
Only the CSS as far as I know...
You can also upload to casio-scene.com
Posted 10 May 2012 - 08:31 PM
There's always cemetech, but that's mainly prizm development.
