Hi, I ned help linking those casio products to my pc, does they use the same cable and program to send data to then pc and to download from the pc to the calculator or digital diary?
Thankss a lot!
Help! CFX 9850G Plus and SF 4900/4950
@Valento!
, Jul 28 2003 09:38 PM
Posted 28 July 2003 - 09:38 PM
Posted 28 July 2003 - 10:41 PM
if it is a casio product i believe that it will work with the casio cable. but you will probably need different programs.
Posted 29 July 2003 - 12:32 AM
I dont know anthing about the SF 4900/4950 but the CFX uses the FA-123 program to transfer files.
Posted 29 July 2003 - 02:06 AM
If you have the SB-87 (or FA-123 as said) cable, then it's ok.
I have a SF-5300E Digital Diary and it works just fine.
If you need the diary software here it is: http://www.geocities...rafx2/casif.zip
#5 Guest_Jorge_*
Posted 08 June 2011 - 01:43 PM
does someone have a manual for digital diary sf-5300E?
