Graphing Linear Equations On A Fx-9860G2
Posted 24 October 2012 - 04:27 AM
plotting points? thanks in advance
Posted 24 October 2012 - 12:25 PM
What do you mean by linear equations? Your calc can do Y=f(x), X=f(y), and f(x,y) graphs. It just depends what mode you select.
You can find intercepts by pressing (while on the graph screen):
Posted 24 October 2012 - 07:15 PM
Hello fixerj and welcome to UCF! You should introduce yourself.
You can find intercepts by pressing (while on the graph screen):F5' /> (G-Solv)
F5' /> (Intersect)
The graph screen can be accessed by pressing MENU->5. Press the <- or -> buttons while selecting an equation to edit it. To change the type of equation (like from x= to y=), press f3.
Posted 24 October 2012 - 10:52 PM
for (3x-6y=12) how is this performed on my cal.fx-9860g2 graph function for Y won't do it.
Posted 25 October 2012 - 06:48 PM
sorry about the intro error please forgive,i have since used the introduction thread to do so.my question is to find the Y and X intercept
hi
you should convert your eqution to this form ( y=(3x-12) / 6 )
and then input that into Y1(Menu/Graph) and hit
after plotting;
for y-intercept two methods are available:
1- hit
2- hit
and input 0 for X-Value
and for x-intercept:
hit
and input 0 for Y-Value
Edited by amin_heidari, 25 October 2012 - 06:49 PM.
Posted 25 October 2012 - 07:48 PM
Another place where casio excels and TI fails...
