Txt To Casio Basic
folkn
, Nov 22 2012 12:21 PM
6 replies to this topic
Posted 22 November 2012 - 12:21 PM
Help!
Is there any Windows software that can convert a .txt file into a CASIO BASIC program? (.g1a,.g1m...)
It seems that all the programs I've found online doesn't seem to work on my calculator (FX9860GII)
Thanks
Folk
Thanks
Folk
Posted 22 November 2012 - 03:15 PM
FA-124 can do it.
- folkn likes this
Posted 22 November 2012 - 03:17 PM
I've tried FA-124 at first, but it didn't work, but now it did! I guess it was some temporary error!
Thanks
Thanks
Posted 22 November 2012 - 03:40 PM
Posted 22 November 2012 - 04:27 PM
SorceCoder is an online application by Kerm Martian that is designed for developing calculator programs. It supports the prizm, and you can convert a text file into a basic one.
Posted 22 November 2012 - 05:20 PM
you can use planet casio generator: http://www.planet-ca...r-de-cours.html
or simon's file converter: http://www.casiopeia...=detail&df_id=4
BTW: if you re using a fx9860, why do you not use a txt reader add-in?
Edited by helder7, 22 November 2012 - 05:20 PM.
Posted 22 November 2012 - 06:21 PM
Unfortunately, that does not support fx-9XXX series BASIC tokens.
